Installing H&R with KYB's
Does anyone know where I can find how-to pics on installing H&R Sport Springs (NOT oe sport) with KYB-AGX Shocks on a 95 Integra GSR? I'm hoping to get it done soon so any help would be appreciated!
i will be ordering the same set-up also, i think it will be a great combo. neo1z had a post about 5 or so below this one, at this current time that ishttps://honda-tech.com/zerothread?id=69432 , where somebody had a pic of a strut assembly. they should go tegether like the pic shows the items in order, if that makes sense. i think you will have to remove the old springs to use some of the old parts, not sure what coomes with the KYB's as far as hardware. or you can go to http://www.autolibrary.org/ half the time the pics don't show but they still have the writen instructions, its pretty simple to put lowering springs on struts, without a spring compressor its still possable, maybe with the aid of a friend to start the nut on top. hope this helped
heres a place that tells you all you need to know. bseries.net <---tells you how to install shock, springs. go to the garage section and clikc on civic/integra
import-tooner
Suspension & Brakes
17
Mar 17, 2009 08:15 PM
