Can I use these injectors on my lude?
Old Dec 4, 2003 | 10:15 AM
96SR-V's Avatar
Default Can I use these injectors on my lude?
RC injectors Specs are 310cc's SATURATED INJECTORS, HIGH RESISTANCE Approx. 12 - 16 OHMS (MEASURED AT 43 P.S.I.G.)
4th gen lude running an OBD1 p72 with hondata... thx
I know 4th gens run peak and hold regularly and thats what I'm running now...
Old Dec 4, 2003 | 10:53 AM
PrecisionH23a's Avatar
Default Re: Can I use these injectors on my lude? (96SR-V)
yes you can
Old Dec 4, 2003 | 10:54 AM
4bidden's Avatar
Default Re: Can I use these injectors on my lude? (GudeH23a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GudeH23a &raquo;</TD></TR><TR><TD CLASS="quote">yes you can</TD></TR></TABLE>
Are you positive?
I tried my buddies 310 RCs from his Civic and the car would start, but definately wasnt right. Very choppy and almost stalling....would not rev.
Old Dec 4, 2003 | 10:58 AM
Default Re: Can I use these injectors on my lude? (4bidden)
Yes. I have ran 2 sets of saturated's on my motor with no problems. Remember, we have a resistor box.
Keep in mind, without a AFC or some sort of fuel management your stock ecu will most likely not idle/start the motor.
Old Dec 4, 2003 | 10:59 AM
alphajesse's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4bidden &raquo;</TD></TR><TR><TD CLASS="quote">
Are you positive?
I tried my buddies 310 RCs from his Civic and the car would start, but definately wasnt right. Very choppy and almost stalling....would not rev.</TD></TR></TABLE>
The guy who asked is running a p72, which hopefully he can remap for the 310 cc injectors. You're running a p13, which is expecting 345cc injectors- your car just plain didn't have enough fuel.
Also, were his peak and hold, or saturated? You might have needed to remove the resistor box- BTW, the poster will need to remove his to run those injectors.
Old Dec 4, 2003 | 11:26 AM
96SR-V's Avatar
Default Re: Can I use these injectors on my lude? (alphajesse)
thx I thought I could as well jsut double checking....
Old Dec 4, 2003 | 11:40 AM
TurboSam's Avatar
Are you positive?
civic from 92 up do not use resistor boxes just like the preludes from 97 up. the just use high impedence injectors
Old Dec 4, 2003 | 04:16 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alphajesse &raquo;</TD></TR><TR><TD CLASS="quote">
You might have needed to remove the resistor box- </TD></TR></TABLE>
No, you leave it as is
Rikaro
Oct 11, 2008 06:10 AM
mahatma
Jun 11, 2007 10:23 AM
Touge Tuning
Apr 27, 2006 08:44 AM
AznBlueBoy
Jul 19, 2005 01:09 AM
nuro
May 5, 2004 03:51 PM
