oil coming out the intake
Old Dec 4, 2003 | 10:13 AM
smokin rubber's Avatar
Default oil coming out the intake
I noticed a puddle under the car while changing my tires after an autocross. I found the source to be the intake filter. I removed the valve breather from the intake and blocked it off and the filter still gets soaked. This is a well abused 184k accord. It this definatly an internal engine failure? The pcv valve is new and is still connected to the IM.
Old Dec 4, 2003 | 11:25 AM
X2BOARD's Avatar
Default Re: oil coming out the intake (smokin rubber)
Looking at your mileage... your valve seals could be shot... (guessing here)
Old Dec 4, 2003 | 12:07 PM
slo2kgsr's Avatar
Default Re: oil coming out the intake (X2BOARD)
we had a case where the engine oil was over filled in the shop that caused that. hope it is something as small as that
Old Dec 4, 2003 | 12:18 PM
Jimmy's Avatar
Global Moderator
Valve Stem Seals quite possibly.
Old Dec 4, 2003 | 06:22 PM
doublejz's Avatar
Default Re: (USDMDC2)
Valve Stem Seals
Old Dec 4, 2003 | 06:58 PM
Default Re: (doublejz)
I thought that the valve seals were normally a cold start smoke problem. She really does run well and doesnt smoke for a car with so many miles.
Are there any tests that can be done to check the seals?
Old Dec 11, 2003 | 10:56 AM
MightyMouseTech's Avatar
Default Re: (smokin rubber)
I would check to see if the oil is overfilled or not. Autocrossing can really slosh the oil around and even send it out the breather tube in hard cornering. I would do a compression and leak-down test to see if the rings are shot or not just to be on the safe side.
If it only happens while autoxing, I would try running with the oil 1/2L down and see if that fixes it.
blackeg
Aug 27, 2013 06:51 PM
jrdnwheeler
Sep 3, 2008 08:48 AM
jvk
Aug 21, 2008 09:59 AM
BlackCRX
Aug 15, 2002 12:12 PM
se93
Dec 27, 2001 06:11 AM
