What cams and compression do you suggest for 180 whp? (B20Z non-vtec)
Old Dec 4, 2003 | 08:03 AM
DevinW's Avatar
Default What cams and compression do you suggest for 180 whp? (B20Z non-vtec)
Just wondering what type of cams and what compression would yield 180 whp on a B20 non vtec. Open to suggestions...also, do you reccommend headwork? Trying to keep it streetable, but I don't mind a lopey idle. Thanks for your help!
Old Dec 4, 2003 | 08:44 AM
JCushing's Avatar
Default Re: What cams and compression do you suggest for 180 whp? (DevinW)
i bet you could get there with a port job 11:1 or greater skunk2 mani other good bolt ons header ect and 404's
Old Dec 4, 2003 | 12:29 PM
whatVTEC's Avatar
Default Re: What cams and compression do you suggest for 180 whp? (JCushing)
404's
Old Dec 4, 2003 | 01:37 PM
Rocket's Avatar
Default Re: What cams and compression do you suggest for 180 whp? (whatVTEC)
You'll want a good header and intake manifold and some larger intake valves too along with a cam that has 280+ gross duration and 11.5+mm lift and some springs to handle that cam.
Also something like hondata to tune it.
Old Dec 4, 2003 | 03:09 PM
Broken Gearbox's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DevinW &raquo;</TD></TR><TR><TD CLASS="quote">Just wondering what type of cams and what compression would yield 180 whp on a B20 non vtec. Open to suggestions...also, do you reccommend headwork? Trying to keep it streetable, but I don't mind a lopey idle. Thanks for your help!</TD></TR></TABLE>
I/H/E, Skunk2 Intake Manifold, Hondata and some nice cams should get you around 180whp if you get some headwork and good tuning then 180whp easily.
Old Dec 4, 2003 | 04:17 PM
whatVTEC's Avatar
Default Re: What cams and compression do you suggest for 180 whp? (2.2L)
To get 180 what kinda compression would it have to be? I want to have about that much NA on my B18b and still be able to shoot 150 shot of nitrous.
Last time I had a dyno tune it was at 156 with the stock ecu.
I have added hondata so I'm sure it could be higher
aj345
Honda CR-V & Element
Aug 25, 2013 04:57 AM
CivSiClone_96
26
Oct 9, 2008 02:54 PM
ganjafarmer143
Sep 25, 2005 05:54 PM
Pony_Fed95
Sep 12, 2005 07:09 PM
ultra efro
Dec 4, 2004 11:41 AM
