help h22 in 91 accord
Old Dec 4, 2003 | 06:53 AM
chulopilong's Avatar
Default help h22 in 91 accord
i have everything in my accord already i just need to know what cv shafts would fit in my h22 and accord. or do i have to buy hasport shafts. another question what is the estimated 1/4 mile run with this engine in a 91 accord
Old Dec 4, 2003 | 07:23 AM
Nick H's Avatar
New User
Default Re: help h22 in 91 accord (chulopilong)
what transmission are you using...if you are using the f22, go with accord axles...if you are using the h22 tranny, go with prelude axles...though i believe either will fit, it's always good to properly match your transmission to axles imo
Old Dec 4, 2003 | 03:45 PM
fizzbob7's Avatar
Default Re: help h22 in 91 accord (Nick H)
no, prelude axles are slightly longer and bind which will cause really quick wear of the inner joint....accord axles with whatever f or h series tranny work much better and are just as good as a stock setup...the ideal setup would be the accord axles with prelude inner joints (slightly stronger)....either will actually work, but after a few weeks, you'll see why one is better than the other
manual tranny needs the accord halfshaft and manual accord axles
auto needs auto tranny parts
that's all you need to remember
i have a 90 h22a accord.......maybe the 94+ are different or something, not sure....
JDM H22
Oct 10, 2007 03:09 PM
rdawg000
Mar 10, 2005 05:53 PM
The Airman
Dec 29, 2004 05:44 AM
hamgumball
Aug 10, 2004 11:36 PM
NitrousBoy
Feb 25, 2003 04:28 AM
