Best Springs
ok....as a few of you might now, i was planning on getting some JDM springs....to make a long story short, im not. so now im wondering, what springs do u guys use and w/ what shocks. im thinking of going w/ tokico illuminas, cause theyre adjustable, and can take what u can give em....+ koni yellows are a bit to much $$$.....fyi i live in MI, so going too low could be a prolbme in the winter, and coilovers are outa the question
...oh one more thing, lemme know if u needed camber adjusters too....sorry for the long post, thanks
john
...oh one more thing, lemme know if u needed camber adjusters too....sorry for the long post, thanksjohn
cylinder the ****....jk unless thats your thing then hit me up... if you want the best do tein full adjustable or middle range like ground control with tokico blue or for just all around spring i would go H & R... good luck
being in MI you should really consider adjustable though im in oregon and they can be life savers...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bagged93accord »</TD></TR><TR><TD CLASS="quote">if you want the best do tein full adjustable or middle range like ground control with tokico blue or for just all around spring i would go H & R... </TD></TR></TABLE>
tein are far from the best...ground control can be competition level if matched with the correct shock....don't do the h&r or neuspeed thing...they have far from aggressive spring rates...
I'd say either H&R or Neuspeed. With the sport you can probably get away without camber adjustment, with the race, you'll want to invest in camber correction.
I have the H&R sports mated to Koni Yellow's, it's great.
gac_gonejeepin
May 31, 2004 12:44 PM
acydphryck
15
Oct 31, 2001 09:02 AM
