1992 to 1994 Spec Dash Swap
Old Dec 3, 2003 | 02:28 PM
TDH's Avatar
TDH
Default 1992 to 1994 Spec Dash Swap
Hi guys, I'm not a regular here so I appologise if this has been done to death.
I tried checking through the search and even went back over loads of old pages in the hope I'd find some answers without bothering you all too much.
Anyways, I have a 1992 JDM Si VTEC with the boring white on black tach and speedo, I've just stripped a mate's 1994 JDM VTEC and have robbed him of his backlit dials.
What I'd like to know is.....
a) Has anyone got a wiring diagram for both of these dash's or can someone point me in the direction of a conversion diagram
b) Are there any pitfalls that I might come up against during the swap.
My 92 is the ultra light model with no sunroof, abs, 4ws or T/C (it did have the climate control but I've junked that)
My mates 94 was all singing all dancing every option box ticked ultra heavy model.
Any help appreciated guys
Cheers
Old Dec 3, 2003 | 02:47 PM
preluda92's Avatar
Default Re: 1992 to 1994 Spec Dash Swap (TDH)
Search for the E.L. guage swap. The guages he has are electro luminescent and everyone wants them. Your a lucky guy to have found one. It's a pretty easy swap if you have all the right parts, and it sounds like you do/can get them. Good luck.
Old Dec 3, 2003 | 03:07 PM
TDH's Avatar
TDH
Default Re: 1992 to 1994 Spec Dash Swap (preluda92)
Cheers mate but that's what I have already tried searching for but nothing comes up as a match anywhere (unless I'm doing something wrong with your search engine???)
Any ideas?
There are loads of those gauges available over here as there are more JDM cars imported than original UK registered stuff.
JDM stuff is the coolest though
Old Dec 3, 2003 | 04:38 PM
ludeR917's Avatar
anyone got pix of this, i have a 95 and my cousin have a 92 and i see no difference.
Old Dec 3, 2003 | 05:34 PM
TDH's Avatar
TDH
Default Re: 1992 to 1994 Spec Dash Swap (ludeR917)
Old Dec 3, 2003 | 05:39 PM
JG Luder's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ludeR917 &raquo;</TD></TR><TR><TD CLASS="quote">anyone got pix of this, i have a 95 and my cousin have a 92 and i see no difference. </TD></TR></TABLE>
Si's have the same gauges 92-96... VTEC's have different gauges from 94-96. SE's have the same gauges as the VTEC with a different redline.
Old Dec 3, 2003 | 05:40 PM
ludeR917's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TDH &raquo;</TD></TR><TR><TD CLASS="quote"> </TD></TR></TABLE>
so... the only difference is the digital milage?
Old Dec 3, 2003 | 05:45 PM
JG Luder's Avatar
so... the only difference is the digital milage? </TD></TR></TABLE>
um... no.
Old Dec 3, 2003 | 05:46 PM
spnbb2
Guest
Posts: n/a
Default Re: 1992 to 1994 Spec Dash Swap (Lone Luder)
no thats incorrect, i have a si and have the el gauges 92-93 = non el gauges 94-96=el gauges<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lone Luder &raquo;</TD></TR><TR><TD CLASS="quote">
Si's have the same gauges 92-96... VTEC's have different gauges from 94-96. SE's have the same gauges as the VTEC with a different redline.</TD></TR></TABLE>
Old Dec 3, 2003 | 05:50 PM
JG Luder's Avatar
Default Re: 1992 to 1994 Spec Dash Swap (Ludinitup)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ludinitup &raquo;</TD></TR><TR><TD CLASS="quote">no thats incorrect, i have a si and have the el gauges 92-93 = non el gauges 94-96=el gauges</TD></TR></TABLE>
I stand corrected.
either way...
Can you see that these gauges are different? They're not "glowing" (as I've heard some people describe it)
Old Dec 3, 2003 | 05:52 PM
Arch-Angel's Avatar
my gauges look exactly like the ones pictured, except for the digital milage, and I have a 92 si...
unless there is some other difference that I'm not seeing here.
Old Dec 3, 2003 | 05:53 PM
JG Luder's Avatar
Default Re: 1992 to 1994 Spec Dash Swap (Arch-Angel)
well then... we (here in America) got fucked.................... as usual.
Old Dec 3, 2003 | 06:02 PM
TDH's Avatar
TDH
As far as I know - All the E.L gauges have got digi mileometer.
If you can read your gauges without the igntion on then you have the standard white on black boring looking jobbies.
Old Dec 3, 2003 | 09:14 PM
fe519's Avatar
basically, how do you and what do you need to convert non electo to an electro
Old Dec 4, 2003 | 12:32 AM
CrazieLude's Avatar
Default Re: 1992 to 1994 Spec Dash Swap (fe519)
1992 and 1993 USDM (and all S models) gauges.
[picture from a 1992 S]
1994-1996 USDM gauges
[picture from a 1994 vtec]
1994-1996 USDM Gauges, converted to blue (crappy pic, doesn't really show the blue)
[picture from same 1994 vtec]
T
Modified by crazieaccord at 3:53 AM 12/4/2003
Old Dec 4, 2003 | 04:57 AM
LudeyKrus's Avatar
I like that last one that's blue, but who in their right mind would spend that much time and money to make such a subtle change?
rharris84
Jan 19, 2007 08:33 AM
myblackhatch
Oct 8, 2006 07:59 PM
ill_imports
21
Mar 15, 2005 08:22 AM
jdmjeff
Dec 31, 2004 06:08 PM
kaoss_11
Aug 21, 2004 06:56 PM
