p72 (GsR) Ecu For 92-96 Prelude? Possible?Whats the Deal?
Old Dec 3, 2003 | 10:38 AM
btrim23's Avatar
Default p72 (GsR) Ecu For 92-96 Prelude? Possible?Whats the Deal?
Hey Fellas, I'm going to turbo charge my h23 prelude si soon and I have search around about h23 turbo car. So far, i found some prelude h23 turbo car that use the Gsr ECU. and i don't understand why? is it possible by switiching the harness? How good is it? Please help me out. i would really appreciate your thoughts and quote.
Old Dec 3, 2003 | 03:17 PM
PrecisionH23a's Avatar
Default Re: p72 (GsR) Ecu For 92-96 Prelude? Possible?Whats the Deal? (etrim23)
The only Si's that run the gsr ecu run hondata and disable vtec. If you run hondata you can also run the p74 or p75.
Old Dec 6, 2003 | 08:17 PM
btrim23's Avatar
Default Re: p72 (GudeH23a)
okay, now i kinda know. thanks.
Also, i call around shops, and they offer 295 for the s200 but i think that doesn't include everything though. and is it easy to wire the harness from the p72/p28 ecu? and how much does a shop charge for wiring it for you? i know it depends on the labor but give me an examples. Can y'all tell me, is it really worth putting the money in for the system and have a technician put it on for you? I do have enough budget for it. All your inputs are appreciated.
Old Dec 7, 2003 | 12:08 PM
luderacer's Avatar
Default Re: p72 (etrim23)
If you have experience soldering boards then you should have no problem but if not you can easily burn your ecu. So it is worth having hondata or someone qualified to install the eprom socket.
Some shops will give you a good deal if you purchase everything from them--ecu, hondata, dyno tuning. Check around. Also you might want to read more in the http://www.hondata.com website.
Old Dec 7, 2003 | 03:12 PM
SKDRCR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GudeH23a &raquo;</TD></TR><TR><TD CLASS="quote">The only Si's that run the gsr ecu run hondata and disable vtec. If you run hondata you can also run the p74 or p75.</TD></TR></TABLE>
which system do you think is better for a turbo h23
hondata s200 or aem ems?
does aem ems even offer anything for the obd1
Old Dec 7, 2003 | 03:59 PM
kb58's Avatar
Banned
Default Re: p72 (SKDRCR)
If you *really* want to get into it... http://www.pgmfi.org/index2.html
Old Dec 7, 2003 | 05:25 PM
BolivianFuego's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SKDRCR &raquo;</TD></TR><TR><TD CLASS="quote">
does aem ems even offer anything for the obd1</TD></TR></TABLE>
Well to me it matters all on who tunes each around your area. Which ever better tuner you have that perfers one over the other i would go with that one.
Old Dec 8, 2003 | 09:52 AM
btrim23's Avatar
Default Re: p72 (BolivianFuego)
thanks guys. I called this place on the internet call (honda-driven.net) they priced the whole system (s200+ecu from skunk, p28)for 807.00 shipped. so i guess i don't have to take it to the shop. i can just plug and play then? if thats how it work. but then to tune it, i have to take it to the shop. or is there anything more i need to do? thanks to all..
Old Dec 8, 2003 | 09:55 AM
btrim23's Avatar
hey i was wondering if i use the hondata system (s200) that use the p74 ecu. how much can i get the p74 ecu for? anyone might know, or have for sale?
Old Dec 8, 2003 | 10:21 AM
The best place to purchase the hondata is through http://www.wiredspeedlab.com, talk to kyle. Those guys get two thumbs up from me.
The p74 ecu will work fine but I believe those do not activate your secondaries which help produce more torque from 2000-5200rpms.
Do a search for p74 or p75 OBD1 ecu's for sale on the board, a decent price is $75 bucks. Talk to the guys at wired speed lab, they might have one laying around.
Old Dec 8, 2003 | 05:18 PM
Ag-Eng's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by etrim23 &raquo;</TD></TR><TR><TD CLASS="quote">thanks guys. I called this place on the internet call (honda-driven.net) they priced the whole system (s200+ecu from skunk, p28)for 807.00 shipped. so i guess i don't have to take it to the shop. i can just plug and play then? if thats how it work. but then to tune it, i have to take it to the shop. or is there anything more i need to do? thanks to all..</TD></TR></TABLE>
BE real careful with this guy....
He's labeled as a scammer here on H-T
If memory serves me well, his name is Charles Campbell or something similar.
BAD JUJU
YEP- Here's the link!! LIST of SCAMMERS!
https://honda-tech.com/zerothread?id=464136
Charles Campbell, H-T name "Honda Driven"
Old Mar 3, 2004 | 09:28 AM
Sam1am26's Avatar
Default Re: p72 (PrecisionH23a)
so if you are using a p74 does that mean your secondaries aren't functional or did you remove them or are you operating them another way? I think I read something about being able to make the secondaries kick in at any given rpm if the secondaries are controlled by another device...
ericstambaugh07
Jun 23, 2007 07:07 AM
darockstar
Mar 10, 2006 06:15 AM
preludesi2188
Nov 22, 2005 10:24 AM
w-fries
Aug 28, 2004 01:49 PM
TurboSam
Nov 14, 2003 06:57 AM
