how do u strip paint?
Old Dec 3, 2003 | 08:58 AM
tekstyle's Avatar
Default how do u strip paint?
i bought a used lip and i need to strip the paint. how do i do this? i tried to sand it down, but it looks like the paint is 1mm thick. do i just sand off the clea coat and then use paint removing chemicals to burn off the rest of it down to the bear ABS plastic?
also, wut kinda of clear coat should i use? ( brand and # coats)
the paint i m gonna use is from a custom shop that mixes paint to the color of your car, so should i just use wutever clear coat they sell?
Old Dec 3, 2003 | 09:05 AM
jbs's Avatar
jbs
Default Re: how do u strip paint? (tekstyle)
Let the chemicals work for you. Use a paint stripper. On ABS plastic, I'm a bit apprehensive. It might melt it off, not sure. Might want to try it off on a hidden part. Brake fluid works wonders too and less harmful to plastic parts. As for the clearcoat, better buy it where you're getting the paint. There are several types and you would want it to be compatible with your paint. Good Luck!
6thgenftw
Paint and Body
12
Jun 23, 2012 06:53 AM
GoLowDrew
Paint and Body
May 16, 2010 05:21 AM
toojdmforschool
Paint and Body
10
Feb 12, 2009 08:52 AM
ferio252
Paint and Body
Mar 2, 2008 06:41 PM
001020
Jul 26, 2004 04:38 AM
