How much could our stock TB's be bored out to?
Old Dec 3, 2003 | 08:29 AM
BolivianFuego's Avatar
Default How much could our stock TB's be bored out to?
How much?
Old Dec 3, 2003 | 10:05 PM
Gerhard_001's Avatar
Default Re: How much could our stock TB's be bored out to? (BolivianFuego)
70mm
Old Dec 3, 2003 | 10:25 PM
SUB-0 H23's Avatar
Default Re: How much could our stock TB's be bored out to? (Gerhard_001)
70mm really that is too much ..isn't? i think the most it can be bored too is 64mm.
Old Dec 3, 2003 | 10:26 PM
speedracer9k's Avatar
is that for all H22 motors and how do you get it bored to 70mm? one more question, what is the stock size for the H22a1 TB?
Old Dec 3, 2003 | 10:28 PM
SUB-0 H23's Avatar
Default Re: (speedracer9k)
60mm
Old Dec 3, 2003 | 11:00 PM
JG Luder's Avatar
Default Re: (SUB-0 H23)
I think I had mine up to 64mm... or was it 68mm...damn... I don't remember now.
Oh well...
Old Dec 4, 2003 | 12:40 AM
TimeRacer's Avatar
Our stock ones can't be bored more than 64mm. Anything larger than that you don't have a wall anymore. If you want something more than 64mm then get a S2k TB or a ITR TB. Those can be bored to around 69mm.
Old Dec 4, 2003 | 12:46 AM
dankbudz11357's Avatar
Default Re: How much could our stock TB's be bored out to? (TimeRacer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TimeRacer &raquo;</TD></TR><TR><TD CLASS="quote">Our stock ones can't be bored more than 64mm. Anything larger than that you don't have a wall anymore. If you want something more than 64mm then get a S2k TB or a ITR TB. Those can be bored to around 69mm.</TD></TR></TABLE>
and those bolt right up to the h22 intake manifold?
Old Dec 4, 2003 | 02:15 AM
TimeRacer's Avatar
Default Re: How much could our stock TB's be bored out to? (dankbudz11357)
Yes, both the ITR and the S2k throttle bodies both match up with the stock intake manifold. You'll have to port match the opening, but they fit great. You also retain the EVAP valve with the ITR (the s2k one doesn't have it as it's located elsewhere on the manifold) throttle body which you generally don't get from aftermarket throttle bodies.
Old Dec 4, 2003 | 03:40 AM
Keith's Avatar
Don't forget the S2K/ITR TB has no Fast idle control valve since it is electronically controlled. As well, the H22 TB can be bored out to a maximum 66mm (stock is 64mm). The S2K is 70mm (stock 66mm).
Keith
Old Dec 4, 2003 | 04:41 AM
pentaq's Avatar
Default Re: How much could our stock TB's be bored out to? (Keith)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Keith &raquo;</TD></TR><TR><TD CLASS="quote">Don't forget the S2K/ITR TB has no Fast idle control valve since it is electronically controlled. </TD></TR></TABLE>
So how can they work in H22? I predict rpms bounce horribly then...
pentaq
Old Dec 4, 2003 | 04:54 AM
TimeRacer's Avatar
Default Re: How much could our stock TB's be bored out to? (pentaq)
Many of us already have the fast idle valve already blocked in a coolant bypass manuver on our stock throttle bodies. Even when I had the S2k throttle body (69mm-&gt;64mm taper bore) I had a rock solid idle of ~800 rpm. Same deal with the fast idle valve blocked on my H22 TB.
Old Dec 4, 2003 | 08:28 AM
screwup's Avatar
My buddy just put an ITR on his prelude. I'm waiting to see how it goes and then I might follow. I'll let you know.
Old Dec 4, 2003 | 02:04 PM
racekar's Avatar
let us know how that works
Old Dec 4, 2003 | 07:04 PM
my friend has a 99 SI and he put a ITR TB on and its throwing codes, where gonna probably put the ITR TB on my h22 to see if it throws codes also, i'll let you know tomorrow if it works or not
Old Dec 4, 2003 | 07:16 PM
Cottonwoodz's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Keith &raquo;</TD></TR><TR><TD CLASS="quote">Don't forget the S2K/ITR TB has no Fast idle control valve since it is electronically controlled. As well, the H22 TB can be bored out to a maximum 66mm (stock is 64mm). The S2K is 70mm (stock 66mm).
Keith</TD></TR></TABLE>
You find me a stock prelude TB that is 64mm, other then a Type-S..
Old Dec 4, 2003 | 09:03 PM
Keith's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pentaq &raquo;</TD></TR><TR><TD CLASS="quote">
pentaq</TD></TR></TABLE>
Nope, I'm running fine and the weather has dipped into the mid-20ies here.
Keith's Avatar
Default Re: How much could our stock TB's be bored out to? (Cottonwoodz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cottonwoodz &raquo;</TD></TR><TR><TD CLASS="quote">
You find me a stock prelude TB that is 64mm, other then a Type-S.. </TD></TR></TABLE>
BAM! I know what I'm talking about dude!
My H22 TB (intake side) 64mm (my ruler is off)
IM side (62 mm)
If you still don't believe me, then I have a Type-S TB to sell ya.
Keith
Old Dec 4, 2003 | 09:06 PM
Keith's Avatar
This my S2K TB after it was P + Ped...
Old Dec 4, 2003 | 09:24 PM
Default Re: (Keith)
Damn the roof is in the pudding.
Old Dec 5, 2003 | 01:20 AM
preluda92's Avatar
Default Re: (BolivianFuego)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BolivianFuego &raquo;</TD></TR><TR><TD CLASS="quote">Damn the roof is in the pudding. </TD></TR></TABLE>
oh **** who put the roof in the pudding! Now it's ruined! ROFl I don't know why but that cracked me up! Oh man, the roof is in the pudding.
Anyway, I want to know if the 70 is really for the turbo guys, or if there could be a rather extreme NA build-up that'd make good use of it.
Old Dec 5, 2003 | 01:35 AM
TimeRacer's Avatar
Default Re: (preluda92)
Throttle body size means much less when you're going FI. It would be one of the absolute last things I'd do if I were tuboed as the air is being forced in already.
Old Dec 5, 2003 | 03:32 AM
pentaq's Avatar
Default Re:
So how technically is that done? As I understand the intake part of TB is bored to 6x mm and polished. Is the butterfly changed anyhow then? If not, how can any gains be achieved as the butterfly diameter is a bottleneck in this situation?
Could anyone explain, please?
pentaq
Old Dec 5, 2003 | 06:00 AM
Keith's Avatar
Default Re: Re: (pentaq)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pentaq &raquo;</TD></TR><TR><TD CLASS="quote">So how technically is that done? As I understand the intake part of TB is bored to 6x mm and polished. Is the butterfly changed anyhow then? If not, how can any gains be achieved as the butterfly diameter is a bottleneck in this situation?
The butterfly plate would need to be changed in the process. Usually, the place that bores out the TB, supplies and replaces the plate.
Old Dec 5, 2003 | 07:49 PM
Your ruler isnt off, Someone just needs to take a measureing class.
