Apexi Power FC / OBD conversion harness / injectors
Old Dec 3, 2003 | 03:50 AM
Andre's Avatar
Default Apexi Power FC / OBD conversion harness / injectors
I have a 94 hatch with a ITR engine, OBD1 harness, OBD1 ECU and Peak & Hold injectors.
I bought a OBD2 Apexi Power FC, what type of conversion harness do i need now? The ones i found are always OBD2 harness with OBD1 ECU. Is the Apexi a OBD2A or OBD2B?? Do i still need Peak & Hold injectors?
Old Mar 4, 2004 | 08:01 AM
onefstek's Avatar
Default Re: Apexi Power FC / OBD conversion harness / injectors (Andre)
The Power Fc its an OBD2a. You will need to get an conversion harness to convert from OBD1 to OBD2a. Everything else will work just fine. 98ctr
roachsboosted16
Nov 16, 2007 10:11 PM
vtecftw
Sep 18, 2007 11:44 AM
FairlightRacing
Aug 9, 2005 08:44 AM
1fstevo
Nov 21, 2003 09:44 AM
