Blown head gasket ?
Old Dec 3, 2003 | 03:04 AM
matix's Avatar
Default Blown head gasket ?
My freinds car is overheating and the idle it jumping from 1 to 2k rpms. I dont know what this could be but was maybe thinking its eighther a blown head gasket or radiator fans not properley working. I noticed the fans were not on when ac is off.Please help
Old Dec 3, 2003 | 04:31 AM
92hybridAccord's Avatar
From: In the heart of the ghetto of the, Suburbs NYC
Default Re: Blown head gasket ? (matix)
A few things to check before making that assumption.
1-Fan will be off if ac is off..turnac on then both fans should come on
2-Check fan switch if fans eventually turns out to be the issue
3-Check the thermostat make sure it is opening
try these before attemting the head gasket cause
Old Dec 3, 2003 | 07:24 AM
matix's Avatar
Both fans only turn on when i turn on the ac. Were is the fan switch and how do i check it. And last were is the thermostat located so i can check that.
Old Dec 3, 2003 | 07:25 AM
matix's Avatar
Wich fan is the condensor fan and wich is cooling fan
Old Dec 3, 2003 | 09:08 AM
iam7head's Avatar
Default Re: (matix)
the passenger side is the one for a/c, the driver side is the old poor bastard
do a voltage check on the cooling system, well, if the headgasket is gone, you can pretty much can tell by looking at the coolant itself
Old Jan 15, 2004 | 09:51 AM
civicminded92's Avatar
Default Re: (iam7head)
I know this post is old, but what became of your friend's car matix? I am going through the exact same problem with my 96 accord. Again sorry to dredge up an old topic but I am just curious.
DerekHollister
Honda Civic (2001 - 2005)
Jul 22, 2016 04:37 AM
Ldo
10
Jan 7, 2009 07:42 AM
whookid007
Oct 11, 2006 07:05 PM
Maxpower350
Jul 20, 2006 09:47 AM
wnadance
Sep 25, 2004 11:24 AM
