Ti Retainers, how long do they last?
Old Dec 3, 2003 | 01:11 AM
crxste's Avatar
Default Ti Retainers, how long do they last?
AS the topic sez, any clues anyone, BTW I'm looking at Toda ones
Old Dec 3, 2003 | 01:59 PM
Propulsion's Avatar
Default Re: Ti Retainers, how long do they last? (crxste)
from what Ive read, they last anywhere from 10k to 40k miles, depending on the brand and the conditions you subject them to. Personally, I decided to just use the stock ones because I won't be reving over 8500 rpm.
Old Dec 3, 2003 | 03:35 PM
Rocket's Avatar
Default Re: Ti Retainers, how long do they last? (SilverCIVIC96)
If you can do this with your sp/ret then they will last a long time.
Old Dec 3, 2003 | 04:38 PM
Big Poppa Pump
Guest
Posts: n/a
Default Re: Ti Retainers, how long do they last? (Rocket)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rocket &raquo;</TD></TR><TR><TD CLASS="quote">If you can do this with your sp/ret then they will last a long time.
If you do what? I just do not understand!
Old Dec 3, 2003 | 04:43 PM
Rocket's Avatar
Default Re: Ti Retainers, how long do they last? (Big Poppa Pump)
Basically everything has to fit snug and the stuff won't wear.
Try doing the above with stock retainers and springs.
Old Dec 3, 2003 | 06:32 PM
phatrick2332's Avatar
^^ exactly...
Why does everyone say ti retainers will wear? Think about it, what causes wear is excessive movement, if there isnt any movement in the springs/retainers..then ur not going to get any wear.
Old Dec 3, 2003 | 08:45 PM
DavidR's Avatar
Default Re: Ti Retainers, how long do they last? (phatrick2332)
100% correct. Also, look how much more material is on those retianers Rocket has...those look meaty!
Old Dec 4, 2003 | 11:12 AM
Rocket's Avatar
Default Re: Ti Retainers, how long do they last? (DavidR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DavidR &raquo;</TD></TR><TR><TD CLASS="quote">100% correct. Also, look how much more material is on those retianers Rocket has...those look meaty!</TD></TR></TABLE>
Yeah, I like the built in safety factor.
oxhernandez
Aug 2, 2006 11:12 AM
HondaCivicSiR1
18
Dec 20, 2005 11:08 AM
hybridEj6
12
Jul 2, 2004 08:37 PM
jeremy.
Oct 21, 2003 09:05 PM
euclid
Jun 30, 2003 07:10 AM
