fuel pressure
what should i set my fuel pis at if i got a 1994 H22A with
-FACTORY LSD
-SHORT AIR INTAKE
-WALBRO 255LPH FUEL PUMP
-AASOC ALUMINUM LIGHTENED FLYWHEEL
-ACT EXTREME CLUTCH
-APEXi N1 CAT BACK
-FREE FLOW CAT
-FACTORY LSD
-SHORT AIR INTAKE
-ACT EXTREME CLUTCH
-APEXi N1 CAT BACK
-FREE FLOW CAT
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H22A EG6 »</TD></TR><TR><TD CLASS="quote">what should i set my fuel pis at if i got a 1994 H22A with
-FACTORY LSD
-SHORT AIR INTAKE
-ACT EXTREME CLUTCH
-APEXi N1 CAT BACK
-FREE FLOW CAT
Within the stock range. You have no need at all for that pump with those mods, by the way.
-FACTORY LSD
-SHORT AIR INTAKE
-ACT EXTREME CLUTCH
-APEXi N1 CAT BACK
-FREE FLOW CAT
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sharkcohen »</TD></TR><TR><TD CLASS="quote">
Within the stock range. You have no need at all for that pump with those mods, by the way.</TD></TR></TABLE>
but it is in a civic cx i dont think that a pump for a 70 hp car will do in a 200 hp car
but it is in a civic cx i dont think that a pump for a 70 hp car will do in a 200 hp car</TD></TR></TABLE>
well you sure didn't tell us any of that in the first post did you? LOL
As far as mods that affect the need for fuel regulation is concerned, you only have a filter on a stick, and a nice flowing exhaust system. 32-36 psi I'd say.
But allow me to say this... the ONLY WAY TO KNOW FOR SURE IS GET IT DYNO TUNED.
Each motor and application is different. There is no "one great fuel pressure setting."
Exactly, a dyno, and just as important, a wideband. Those will help you get the pressure exactly where it needs to be.
I understand needing a better pump, but the LPH model was overkill.
ok thanks i got the pump b/c it was cheap and i might need a little extra if i decide to boost thank you gus for your valuable thoughts
HotWheelz
Nov 8, 2003 07:36 AM
