My 85 CRX autocrosser
I need some kind of noise other than the engine when I drive it for over an hour!!!!
and you'll learn to live with out having other noises besides the engine.
i do like the gutted interior though
[Modified by JunkeeCrx, 11:49 AM 9/17/2001]
Thanks for putting the pics up. It's an insparation for me to get off my butt and go back to work on my 87 crx (needs a lot). Did you paint over the interior tar? I'm in the process of removing it right now and it's a pain in the ***.
The interior of the car was like that.....I bought the car as a former bracket drag car, and it's now solely an autocrosser. I'm working on the rear tar at the moment. That stuff actually does weigh some, so it is worth the hassle...but, I'd recommend dry ice or something of the like to harden it up first. I'll probably work on that part more in the winter. My other project for the car this winter is to hand fabricate either an aluminum or carbon fiber dash, with some type of integrated defroster out of JC Whitney, to allow this thing to pass inspection (small requirement of a local sports car club). This car should be a higher 14 second car now (14.8 - 14.9). Not terribly impressive, but handles great. Cept the ACT 4puck clutch is a bit tough for any reasonable driving.
where do you autorcoss - i also race an ep 86 si. have you put in a racing cam? that makes a huge difference. what about boring out the engine? you can put the integra 1.6 pistons and rings in that block without a problem with the clearance. you can also use the integra ecu to give you a higher rev limiter. the crx wiring harness plugs right into the integra ecu, no manipulating. you can also lower that car a lot more than you have in your pics.
good luck with racing, i hope you are doing well!
man have you stereo stolen a few times
No one will be stealing the stock Honda radio pumping out the beats to the one stock Chrystler speaker I have.
~rick
Corksil
Jan 1, 2012 10:51 AM
DoubleDirtyC
15
Dec 21, 2009 06:25 PM
Efbluevtec
Jun 29, 2007 07:34 AM
hotwheeelz
Sep 3, 2006 12:43 PM
NINJASPY
20
Aug 24, 2003 09:53 PM
