Weight Reduction Tip #246
Aluminum lug nuts.
All 25 aluminum lugs weight only 14 oz which means each individual lug is just over 1/2 oz (.56 oz each). The stock steel lug nuts together weigh in at 23 oz or (1.1 oz each). I’m not exactly sure why the aluminum lugs are quite a bit longer than the stock ones. They are probably designed that way so they fit more applications.
I do not know what brand they are but I got them from http://www.bigbeartire.com a while back when my TE-37’s were put on the car. They cost about $2.50 per lug.
Steel:
Aluminum:
[Modified by itrsport.com, 9:36 AM 9/17/2001]
Aluminum lug nuts.
Steel:
Aluminum:
Hmm.....interesting....but only the differences of 13 oz? I'll dehydrate myself before driving and it's a good 3 pounds of weight reduction.
[Modified by nEoMuGen, 5:42 PM 9/17/2001]
Mmmmmmm, rotational weight!!
Anything that moves/rotates that is lightened is significantly better than stationary weight.
Only problem with amunimum is that it strips easily. But at least the bolts will strip, and not the lug threads!
patrickd_21
Mar 12, 2012 06:00 PM
S@nt0s
90
Sep 21, 2004 06:50 AM
