ITR suspension on 88 CRX?
Old Sep 17, 2001 | 07:12 AM
Speed PHreak's Avatar
Default ITR suspension on 88 CRX?
I know the ITR rear shocks/springs will fit on an 88 CRX, how about the front shocks and springs? My stock **** is gone and needs replacing, I can get ITR stuff from jdmhondaparts for a pretty good deal.
any help appreciated.
steven
Old Sep 17, 2001 | 07:34 AM
RyanR's Avatar
Default Re: ITR suspension on 88 CRX? (Speed PHreak)
It will fit but you'll also need the ITR front shock forks. The ITR shocks are thicker than the CRX shocks. The ITR suspension will also raise your car up about an inch.
Old Sep 17, 2001 | 07:53 AM
Default Re: ITR suspension on 88 CRX? (97TypeR_9)
Hmmm its not a prob to get the front forks, I don't know it being raised up an inch, how would that affeect the handling of the car? Ya think it would look funny? Would it affect my camber/alignment raising it up?
~steven
[Modified by Speed PHreak, 4:55 PM 9/17/2001]
Old Sep 17, 2001 | 08:16 AM
RyanR's Avatar
Well if you use stock springs you'll probably end up getting positive camber. Just get some springs that lower the car a couple inches and you'll be fine. Sport springs would probably work best. They will lower the car a little and they're not so stiff as to the point were they blow out your shocks. Just get an alignment after you do all the suspension work to correct the toe.
Old Sep 17, 2001 | 08:49 AM
Sport springs? who are the made by? However if you notice an ITR is already lower than a LS/GS-R to begin with. I looked up the lowering springs an IP.com and most said that the type-r would recieve minmal lowering(eibach sportline to be exact).........just an observation tho.
[Modified by Speed PHreak, 5:54 PM 9/17/2001]
Old Sep 17, 2001 | 09:22 AM
RyanR's Avatar
The Type R springs lower the car 10mm. Not that much really. Just get some Eibach or Neuspeed sport springs.
Old Sep 17, 2001 | 09:27 AM
Noted. Thanx for all your help man, I relly appreciate it.
integra95gsr
Nov 7, 2005 12:03 PM
fongph
Suspension & Brakes
Jun 25, 2005 02:48 AM
mugenracer
Feb 3, 2005 04:52 PM
andrew n
Apr 22, 2002 09:52 AM
Speed PHreak
Sep 18, 2001 08:39 AM
