OBD1 P28 ECU - Injector Impedence?
I have a p28-a02 obd1 ecu. I am wondering if I still need a resistor box or not. Do the injector drivers use low or high impedence? What year did honda switch over from p&h to saturated? Also, with my Hondata, all I need is Hondata, p28 ecu, and harness right? No other wiring necessary? My engine is a obd-2 b16a2. thanks
All honda ecu injectors drivers will accept high impedance injectors directly, the non obd ecus used an external resistor box with the low impedance injectors.
You can run either injectors with that ecu. Just remember to have the resistor box if you want to run the P&H injectors. Likewise, no resistor box is required for the saturated injectors.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99 ls integra »</TD></TR><TR><TD CLASS="quote">in response to your questions 96 and up are saturated p& h is before that </TD></TR></TABLE>
Wrong: 92+ Civics use high impedance (saturated) injectors.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EE_Chris »</TD></TR><TR><TD CLASS="quote">
Wrong: 92+ Civics use high impedance (saturated) injectors.</TD></TR></TABLE>
no they don't i called acura dealership and they said 96 and up is saturated below that is p & H that is at least in prelude and acura in those years here are some other posting with exact numbers i'll find the link with the website soon 1988-'91 Civic Si/CRX Si Peak and Hold 240cc
1992-'95 Civic Si/EX Saturated 240cc
1996-'00 Civic Saturated 240cc
1990-'91 Integra RS/LS/GS Peak and Hold 240cc
1992-'00 Integra LS/GS Saturated 240cc
1992-'96 Prelude Non-VTEC Peak and Hold 240cc
1992-'96 Prelude VTEC Peak and Hold 345cc
There.
There.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99 ls integra »</TD></TR><TR><TD CLASS="quote">no they don't i called acura dealership and they said 96 and up is saturated below that is p & H that is at least in prelude and acura in those years here are some other posting with exact numbers i'll find the link with the website soon
There.</TD></TR></TABLE>
You tell me I'm wrong then say the same thing I said???
that's not what i am talking about i am talking about the set up he had would it work would he need a resistor box u need a resistor box if u use 345 prelude injectors
beef-cake
Jan 23, 2007 08:10 PM
MysteryWagon
Jun 15, 2005 09:35 PM
Power Rev Racing
May 20, 2005 10:20 AM
Black R
Aug 31, 2003 03:05 PM
