JDM Fender Brace - help with install
the usdm brace will not fit, so i bought the JDM one... but i cant the USDM one off!! the bolt in the pic just spins and spins.... any help? the second pic is a zoomed out view of the area... thanks...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d8168055 »</TD></TR><TR><TD CLASS="quote">impact? u mean have someone hit it from the top??</TD></TR></TABLE>
No, impact gun
not a .45 colt but a mechanic's tool, like a air ratchet.
No, impact gun
look inside the eng. compartment you should see a square nut on the other end of that bolt. now if its spinning along with the bolt then all you need to do is hold that nut with a wrench or vise grip.
ohh.. the thread on the bolt is striped. then try and put something to pry the bolt or bracket out while you unscrew the bolt. you might get lucky and it catches and it will come out. if not then you will need to cit the head of the bolt then drill out the old bolt. or cut the wel of the nut and just use a new bolt and nut.
