how much for a wiring harness
Old Dec 1, 2003 | 07:11 PM
ISawUL00k's Avatar
Default how much for a wiring harness
How much can i get a wiring harness for. i have a 92 civic hatch VX with b16a.
which harness do i need obd ? whats this mean ?
What type of ecu ? thanks
Old Dec 2, 2003 | 06:02 AM
doublejz's Avatar
Default Re: how much for a wiring harness (ISawUL00k)
if its a first gen b16 then you need an obd 0 harness if its a 2nd gen you need a obd1 harness. You will also need to run a knock sensor wire if your ecu isn't chipped and also the vtec wire, from your shock tower.
do a search the answers are out there
Old Dec 2, 2003 | 10:59 AM
ISawUL00k's Avatar
Default Re: how much for a wiring harness (doublejz)
yah. I search but its all buy this and buy that ! I can never find a good link. can i put a obd1 ditributer on a 1st gen b16 head ? say i was to buy a complete 1stGen b16, and i wanted to replace my b18 longblock with this new 1st gen b16. can i use the harness , the manifold, ECU (chipped Mugen Pro) , headers,and 0bd1 ditributer, alternater, half shaft,. and can i use cable axles in hydro trans..
thanks
Old Dec 2, 2003 | 12:23 PM
Turbogixxer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doublejz &raquo;</TD></TR><TR><TD CLASS="quote">if its a first gen b16 then you need an obd 0 harness</TD></TR></TABLE>
I would say that he should go with a OBD1 harness with a first gen. Why? he will run a OBD1 ECU (i hope so) and all the plugs will be there. OBD1 and OBD0 have a few things different from each other (ECT, dizzy plugs, resistor box). I would only run a OBD0 harness in a OBD0 car.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ISawUL00k &raquo;</TD></TR><TR><TD CLASS="quote">can i put a obd1 ditributer on a 1st gen b16 head ?</TD></TR></TABLE>
Yes, all PR3 (all OBD) are the same (within reason now).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ISawUL00k &raquo;</TD></TR><TR><TD CLASS="quote">say i was to buy a complete 1stGen b16, and i wanted to replace my b18 longblock with this new 1st gen b16. can i use the harness , the manifold, ECU (chipped Mugen Pro) , headers,and 0bd1 ditributer, alternater, half shaft,. and can i use cable axles in hydro trans..</TD></TR></TABLE>
If you have a LS swap already. Just use the B16 as a long block. Yes, I would use the intake AND TB (your LS TB will not work). For ECU, I would run a P30 or a chipped p28. IF you reuse your LS dizzy, you will have to trim the ears (the pieces where the bolts go through). It will will with only one bolt holding it in. Use your LS injectors and rail, it will bolt on, no mods. Your LS alt will work with the B16 bracket and your LS (same). Use your LS intermediate shaft and axles. You will have to reuse your LS thermostat housing because OBD0 ECT are on the block and OBD1/2 are on the thermostat housing. If you do not have the axles, 94+ integra will work.
Now, I have some questions for you. What harness you using? VX or other? (EX or SI harness will be almost plug and play, only knock sensor to D3) Why not LS/vtec?
Last but not least, you have a VX and a 92, it is wiring for Vtec already.
oh, <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ISawUL00k &raquo;</TD></TR><TR><TD CLASS="quote"> headers,</TD></TR></TABLE>
is that new race headers for b-series I have been hearing about?
Old Dec 2, 2003 | 04:23 PM
ISawUL00k's Avatar
Default Re: how much for a wiring harness (turbogixxer)
92 vx with 96 b18b harness..port matched b16 manifold , ported & polished gsr TB ,DC4-1 header. pig fuel pump,vafc,gsr trany ACT 2600 lbspp /w 6puck,stage 3 port & polish, valves springs, retainers, valves, ITR motion assembly, x2 micro on crank,balanced & blued...ITR pistons...ITR water/oil pump MSD 6AL ,Mugen Chip i dunno what ECU
it was a runnig ls/vtec but i dont like the R/S and no oil squirters.i wanna REv that B.plus i have to run b16 in autocross event.
so an obd1 94-96 integ harness distributer is compatible the 1st Gen b16 head and bottomend
<U></U>
this car was built for drag but i want to be able to interchange the b16 and b18
i got it all i just need to figure out what is interchangeable
wish i got it a dyno before i tore it down
thanks
Old Dec 2, 2003 | 08:14 PM
salbaje's Avatar
if you need parts hit me up
Old Dec 2, 2003 | 08:18 PM
Lord Helmet's Avatar
http://www.importautosalvage.com quoted me awhile back (4-6 mths) on a b18c1 engine harness for $250 shipped. hope that gives you a rough idea.
Stray
Apr 20, 2007 07:40 PM
Youlose1305
Sep 28, 2006 03:10 PM
my_slow_civic
Oct 27, 2004 09:43 AM
91teg
Sep 1, 2004 06:06 PM
