need more power. no boost for me.
Old Dec 1, 2003 | 04:24 PM
I Have an STD's Avatar
wrenchin'
Default need more power. no boost for me.
ok, im running an LS/VTEC setup in my eg sedan. its a stock b16 head with a stock LS block with about 70k and its starting to blow smoke a bit. so its time to rebuild. i need a ton more power on pump gas. i want a cost effective all motor answer. what pistons?? what rods?? i want about 210 whp. im also looking to do an extra 50 shot of spray. i have a winter car/second car so i can pull the motor for awhile. what should be done?? and what cams too??? i need over 200 whp and a nasty *** vtec changover. please let me know, i need to start buying parts.
Brett
Old Dec 1, 2003 | 04:33 PM
lsvtec hatch05's Avatar
i am building my lsvtec right now too and i would say go with je 11.5:1 pistons and eagle rods, if you want to go with big cams i would say skunk 2's, but ctr cams work just fine
Old Dec 1, 2003 | 06:32 PM
Big_Mike's Avatar
Default Re: (lsvtec hatch05)
go with a higher compression 12:1, spend some $$ on the head and get some cams, bigger bore wouldn't hurt either.
Old Dec 1, 2003 | 09:44 PM
turbo*s2k's Avatar
Default Re: (10s_ALLMotor)
How will that high compression do with 92 octane? Or depending on location 91 or 93. Just curious. Will you have to run octane booster all the time?
Old Dec 2, 2003 | 06:44 PM
wrenchin'
Default Re: (TurboChrgd_Civic)
i get 93 octane where i am. i was told i can get a full bottom end built for $1300, labor included. this is including any spec je piston i want. im thinking dome top 12:1. eagle rods are also included with this setup. ill be using the lightweight rods and the stock LS crank. do i need headwork right away? i know that ill need it pretty soon after the bottom end build, but ive got the offer for that price right now. i can install the cams with the head on the car. id like it to run 13s with a stock head and the high compression bottom end. is it possible?
Brett
Old Dec 3, 2003 | 08:13 AM
Default Re: (AngryBlackSedan)
$1300? man you buy the block, buy the pistons and rods. you can get em for like $850 and you find somebody that knows how to put it together(if you don't know how) for like some cash or some beer or something along those lines and you have yourself a bottom end and you saved yourself alot of money. i am running a stock head with ctr's and cam gears. mine does just fine. what head are you gonna use or you already have?
Old Dec 3, 2003 | 05:39 PM
wrenchin'
i have a b16 head on a b18b block. i thinking of picking up another block and building that so there is no time when the motor is out of the car for that long. yeah, i think thats what ill do. but what pistons should i go for?? i dont know if i need to go with forged with that much compression (plus no oil squirters on my Ls block) or should i just go with like an ITR piston setup?? i dont know what to do yet. i need to know what u guys think. i only wanna do this once, not pull the motor 4 times a year.
Brett
Old Dec 3, 2003 | 06:29 PM
i am personally running je 11.5:1 pistons. if you want a fast, strong motor i would get pistons besides itr's. even though i do have some itr's for sale if your interested, if you do go aftermarket pistons, i would suggest going after market rods too
Old Dec 6, 2003 | 11:41 AM
wrenchin'
i think thats what my plan is right now. but i might be picking up some individual throttle bodies for a little DIY project. is this a good idea??
Brett
Old Dec 6, 2003 | 12:31 PM
TypeR_Turbo's Avatar
You should go with:
Darton MID Sleeves
JE 85mm 11:5.1 Comp.
Crower All Motor Rods
Skunk2 Stage 2 Cams
Skunk2 High Comp Valves (standard size)
Go with a big bore and sleeve your block. Lotsa power!
Old Dec 6, 2003 | 12:45 PM
b00sted4dr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lsvtec hatch05 &raquo;</TD></TR><TR><TD CLASS="quote">$1300? man you buy the block, buy the pistons and rods. you can get em for like $850 and you find somebody that knows how to put it together(if you don't know how) for like some cash or some beer or something along those lines and you have yourself a bottom end and you saved yourself alot of money. i am running a stock head with ctr's and cam gears. mine does just fine. what head are you gonna use or you already have?</TD></TR></TABLE>
but hes still gonna have to bore, hone, and deck it.
Old Dec 6, 2003 | 07:09 PM
Default Re: (96gsr4dr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96gsr4dr &raquo;</TD></TR><TR><TD CLASS="quote">
but hes still gonna have to bore, hone, and deck it. </TD></TR></TABLE>
still save him some money to put the motor together himself insead of somebody assembling it for him.
Old Dec 7, 2003 | 02:21 AM
Unsung's Avatar
Default Re: need more power. no boost for me. (AngryBlackSedan)
You can't go wrong with stock honda parts for a cheap build. I've seen CTR piston/cammed LS/VTEC's put down around 200whp.
BlueRex1020
Nov 20, 2009 06:57 PM
Amped
Dec 3, 2006 10:30 AM
Andres-eh2
11
Sep 14, 2006 07:23 PM
HaTcH_BmX
Feb 13, 2003 12:47 PM
infamousALLMTR
Mar 16, 2002 03:59 PM
