need help removing stock cat???
Old Dec 1, 2003 | 11:14 AM
Krayzielix's Avatar
Default need help removing stock cat???
im replacing my stock with a highflow one..how do i remove the stock one??
Old Dec 1, 2003 | 11:17 AM
solsteeler's Avatar
Default Re: need help removing stock cat??? (k12ayz1e)
There should just be a few nuts holding it to the exhaust pipe.
Old Dec 1, 2003 | 11:22 AM
scratchy's Avatar
you have three bolts on each side but i can almost gaurentee that they are rusted the **** on so you can either heat them up or drill them out good luck its a bitch i have done enough i my day so good luck
Old Dec 1, 2003 | 11:29 AM
Jimmy's Avatar
Global Moderator
Default Re: need help removing stock cat??? (scratchy)
Get underneith your car the night before you plan on changing them and soak them in WD-40 then tomorrow try and take them off and it shouldnt be near as hard. Btw: Is there anything wrong with your stock cat?
Old Dec 1, 2003 | 11:31 AM
Krayzielix's Avatar
Default Re: need help removing stock cat??? (USDMDC2)
aite...thanks for the advice
95lsinteg
Nov 2, 2003 09:18 AM
FrostyDC4
Jan 12, 2003 04:12 PM
91hondacrx
11
Jun 19, 2002 09:54 PM
