88 Accord ECU
When replacing an ECU, does the ECU part number have to be exactly the same?
Will an ECU from a 1988 Honda Accord EXI 4 door work in a 1988 Honda Accord EXI 2 door coupe. Both have the same engine and auto transmission. I have the part number for the coupe, 37820-PJO-668. The other car is 100 miles away, so I can't get the numbers.
I learned this the hard way.... the part numbers MUST be EXACTLY the same for it to work properly. Not knowing this for sure I got an ECU from an 88 LX-i (identical to mine, even down to the color, lol), and sure enough it didn't work. It started up and everything, but as soon as I turned the a/c on it boosted the idle to about 2000 rpm, LOL. I didn't even try anything else cuz I didn't want to fry anything.
If the numbers are the same, go ahead and get it. I know the auto and manual tranny cars had the same ECU, pretty sure coupe and sedan did too. Just make sure the numbers match and you'll be good.
hondanoob1
Aug 17, 2018 06:57 AM
