running rich...S-afc. Chipped Ecu. Built Motor, backfiring and shootin alittle flame
Well i have a built motor and stuff (look in sig for details). Well i installed my S-AFC and a belray ecu a while ago. And after doing so it runs very rich i get like 10mpg and when i **** about 8,000 rpm it backfires and shoots alittle flame out.
Well i know its running rich i have it set up to a bit more fuel then stock like around 4-6000 its like 9% more on my afc and at 6-8000 its about 5% more i think.
My question really is how can i lean it out to a point wherre i know its safe. i dont want to just lean the afc out then have it to lean and blow a rod at like 8k. Should i just set everything down like 1% and just keep doing that untill i feel its better. I know a Dyno is only the true way to tell but i cant get access to one for a while
any thoughts on this would be great.
also is that an ok setting for the fuel 9%-5% increase over stock on the AFC or does that seem to much? I feel that the chipped ECU is dumping alot of fuel into my car over the stock one which i wasnt expecting that is why i raised the AFC fuel up. So should i lower it alot?
thanks alot
mike
thanks alot
mike
From: Bluffton/Hilton Head,SC / Ft. Lauderdale, FL, usa
...theres no way to for anyone to tell u a good(safe) setting..without a true A/F reading..and even if u try to copy someones elses settings remember all motors (even with the same mods) will vary....since no dyno is available..maybe u should look into one on these
http://www.innovatemotorsports.com/
Modified by bruceleeroy at 12:27 PM 12/1/2003
thanks for the link, seems good kinda pricy though
yeah see thats the thing i know i cant copy neone else becuase every motor is different. im just seeing if neone with alot of tuning experience could help me point me in the right direction. i can give more info if ppl need and my exact afc settings and stuff.
thanks neway!
.yeah see thats the thing i know i cant copy neone else becuase every motor is different. im just seeing if neone with alot of tuning experience could help me point me in the right direction. i can give more info if ppl need and my exact afc settings and stuff.
thanks neway!
i see.....well start at zero, *** tune it and read the plugs...not the most conventional way but i guess u have no other choice?....just a thought...good luck!
So your chipped ecu is running rich. And then you used the AFC to add more fuel.
I have no idea why it might be running rich
-PHiZ
you can KINDA use a regular narrowband to tune it up, NA (well, you didn't post your compression), I think you have plenty of margin for safety. But really a wideband is the best idea, and yes you will see huge gains, **** bite the bullet and find a dyno tuner that will wideband dyno-tune your AFC for ya.
-PHiZ
my compression is low. 9.8:1 ( i got the pistons for turbo but couldnt finish turbo project so i went NA)
well i am running rich on the AFC for sure. but i think the ecu is makign my car run alot richer as well on top of that but im not sure as i put it all in at the same time but im like 90% sure its causing me to dump alot more fuel in
i know a few friends that said they will help me out. and they pointed me to a dyno about 4 hours away. they charge $75 for 3 runs and will tune the afc i think thats what he said so when i get break from college i might go down. i think for now i might as well run rich its better then leaning it out to much
If you buy a good...and i stress GOOD egt probe (and gauge) you can also get
and idea- Just go on the highway...do a 4th gear run and see what your egt's are.
Lean it A LITTLE and try again- I think on a honda engine 15-1600 deg. is about
the limit (to hot/ to lean) I'd say 1200-1400 @ wot in 4th- I set my v-afc hack like
this with a turbo setup and it did well.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91tegrals »</TD></TR><TR><TD CLASS="quote">i would try and get it dyno tuned...</TD></TR></TABLE>
He's right, I'd save up and go for a road trip to the nearest dyno.
thanks guys for the advice. i had an egt guage for my talon maybe i will go ahead and get one for the teg. kinda expensive but i guess worth it.
thnaks alot for the help
erikiksaz1
Engine Management and Tuning
Jun 11, 2010 02:39 PM
jc2801
Aug 28, 2008 11:50 AM
The Mista Mike
Nov 13, 2006 09:08 AM
