Lots of Parts from a 1995 Civic Si plus porting and polishing
Old Dec 1, 2003 | 07:25 AM
Dokta's Avatar
Default Lots of Parts from a 1995 Civic Si plus porting and polishing
ABS module includes the pump, resavoir, modulator, and accumulator.
$200 shipped
ABS computer
$140 shipped
Cruise control servo
$60 shipped
Cruise control computer
$75 shipped
Fuel pump 65,000 miles
$70 shipped
2 x Visonik V1265S4 12" 700 watt Component Subwoofers,
a Power Acoutik 1400 watt 1 Ohm Amplifier, and
a custom built 3.8 cubic ft enclosed box with gold connectors.
$375 shipped
2 x JVC 6"x9" 100 watt 2-way multi-element coaxial speakers
$80 shipped
Air conditioning compressor, AC condensor w/ fan, AC evaporator, all hoses, tubes, and everything you need to convert your civic, except the refrigerant.
$375 shipped
All parts from a 1995 Civic Si, and will fit all 92-95 Civics
Cylinder Head Port & Polish
-complete visual inspection of head
-check all surfaces for straightness
-complete disassembly
-label all parts
-inspect valve train components for wear
-degrease and clean head of oils
-remove all studs & lap all surfaces
-deshroud and debur all runners and combustion chambers
-full port and polish of runners and combustion chambers
-shape valve guides
-antireversion measurements applied
-lap valves and valve seats
-replace valve seals
-final cc check
-reassemble complete head
16 valve 4 cylinder head - $500 shipped
24 valve 6 cylinder heads (both) - $660 shipped
16 valve 8 cylinder heads (both) - $720 shipped
4 cylinder intake manifold - $180 shipped
Throttle body - $100 shipped
4 cylinder head milling .005" to .050" - add $85
Please contact Manny at jojoshabadoo@hotmail.com
Old Dec 1, 2003 | 11:57 AM
Dokta's Avatar
Default Re: Lots of Parts from a 1995 Civic Si plus porting and polishing (Dokta)
ttt
Old Dec 9, 2003 | 09:20 AM
Dokta's Avatar
ttt
Old Dec 15, 2003 | 04:25 PM
Dokta's Avatar
ttt
Old Dec 24, 2003 | 09:38 AM
Dokta's Avatar
ttt
Old Dec 24, 2003 | 11:55 AM
EH339's Avatar
Your '95 Civic Si had factory ABS? You sure that it's a '95 and not really a '94? ABS was only available in '94 with the EG Si's, and even then, only some of them had this option... well I bookmarked your page. Have no extra money this week.
Old Jan 6, 2004 | 07:58 AM
Dokta's Avatar
Default Re: Lots of Parts from a 1995 Civic Si plus porting and polishing (94RedSiGal)
Actually the ABS parts are from a 1994 EX. Good catch, I'm impressed. Not many people would have known that.
Old Jan 21, 2004 | 12:11 PM
Dokta's Avatar
ttt
Old Feb 7, 2004 | 12:03 PM
Dokta's Avatar
ttt
ryc555
May 8, 2012 07:59 PM
coquinn
Mar 29, 2002 04:28 AM
