itr oilpump
Old Dec 1, 2003 | 04:44 AM
vtidave's Avatar
Default itr oilpump
Hi,
I'm working on my ls/vtec and have the following problem;Ive installed the itr oilpump and found out that the b18b1 "belt-gear"doesnt fit because of the teeth from the crank sensor.Ive already modified it by cutting of the teeth,but i don't know if this is the right way.Does anyone had similair problems with that?Thank you,
greetz,Dave
Old Dec 1, 2003 | 06:28 AM
vtidave's Avatar
Default Re: itr oilpump (vtidave)
HELLO?
Old Dec 1, 2003 | 07:14 AM
len's Avatar
len
You did what!?
Old Dec 1, 2003 | 08:00 AM
vtidave's Avatar
Default Re: itr oilpump (len)
I've modified the belt-pulley(small pulley behind crankpulley) from the b18b1 so it fits on the itr pump.That's my best way to describe it,(i'm Dutch),greetz,
Dave
Old Dec 1, 2003 | 08:51 AM
sander's Avatar
2.7(p/t)
it shouldnt need to be modified. Mine works just fine with my ITR oil pump. are you sure you bolted your CKP sensor on right?
-sander
Old Dec 1, 2003 | 11:52 AM
eg_type_r93's Avatar
Default Re: itr oilpump (sander)
i got a b20b oil pump the same as the itr but with the right amount of teeth for your belt
email me if interisted
eg_type_r93@yahoo.ca
daniel
SupaFly_Honda
Jan 26, 2004 12:42 PM
