Cracked turbo manifold
Old Nov 30, 2003 | 07:12 PM
aznxphreak's Avatar
Default Cracked turbo manifold
Well, it finally happened. After 3 years, I developed a crack in my manifold. Checked earlier today and it totally split right before the flange connecting to the turbo. So my turbo is basically loose and my car sounds like it's running open header. Can this be welded back together? How much should it cost with labor? I tie wrapped the wastegate so it doesn't move around that much... =T
Old Nov 30, 2003 | 08:02 PM
Hondasi88's Avatar
what kind of manifold are u using?
Old Nov 30, 2003 | 08:06 PM
Tinker219's Avatar
Default Re: Cracked turbo manifold (aznxphreak)
it could probably be welded no problem if it was NOT a cast manifold. Even a cast one could be welded if the welder/shop was accomplished enough...
black_99SI
Jun 12, 2008 11:23 AM
fin781
Dec 13, 2007 12:51 PM
genop
Jan 30, 2002 12:52 PM
Jon7
Aug 6, 2001 11:55 AM
