CAMS
Old Nov 30, 2003 | 04:37 PM
slotec95's Avatar
Default CAMS
Does anyone know where i can get a cam for a 95 accord ex. I am trying to build the head in my car and i want to replace the stock cam with a bigger one. Thanks i n advance.
Old Nov 30, 2003 | 05:31 PM
fw190bvi's Avatar
Default Re: CAMS (slotec95)
u cant get HP for F22s....why.....cause none cares enought to make good cams for the beautiful SOHC F22.....alas......
Old Nov 30, 2003 | 06:36 PM
GreenD's Avatar
http://www.webcamshafts.com/whatauto.html
http://www.exospeed.com/engine/cams/f22cams.htm
http://www.honda-performance.c...D=189
its not on the site, but delta does a f22 regrind. http://www.deltacam.com
http://www.gude.com/catalog/cat_accord.html
these are just a few. im sure theres more...
Old Dec 1, 2003 | 12:08 PM
fast93accord's Avatar
No one makes a standard new cam for the F22, however if your willing to fork over about $800-$1000 you can get a custom one made. I recently put a reground cam in my car. Awesome results. Its by Delta camshafts.
Its called the 272 grind. It has .425" lift, and 272 degrees of advertised duration. 113degree lobe seperation. My car has a noticable change in idle, and a lot more power. They told be this is a great nitrous cam, and it is. I feel i gained about 15HP at 6500rpm and it wants to rev to about 7500, but i need some other stuff before i rev it that high. When i spray my nitrous i feel an easy 20-30hp gain with this cam. Cant wait to get it to the track.
Old Dec 1, 2003 | 12:18 PM
KGAccord's Avatar
Default Re: CAMS (fast93accord)
regrinding a cam takes some of the strenght away from the cam and you are limited to what can be grinded. i think your money is better spent going H22 swap if you wish to be N/A.
Old Dec 3, 2003 | 08:06 AM
knowtomorrow3001's Avatar
I think Gude could get you one
Old Dec 3, 2003 | 08:42 AM
Nick H's Avatar
New User
Default Re: CAMS (knowtomorrow3001)
talk to a guy named Rocket on http://www.ef-1.com
you might have to fork over your cam so that he can do R&D on it for a little while, but it'll be worth it...his regrinds are some of the best i've ever seen...
BrothaSit
Mar 4, 2011 12:04 PM
Bob_760
May 7, 2007 06:03 PM
the fallen ex
Jan 15, 2007 05:56 AM
double0Si
Mar 3, 2003 08:10 PM
BEEFEDUPACCORD
Apr 14, 2002 06:15 PM
