Car wont start!!!!
Old Nov 30, 2003 | 03:37 PM
lonefuzzy79's Avatar
Default Car wont start!!!!
The problem started a little while back, while in my 95 civic CX with 92 d16z6 swap. There was an electric sounding poping and crackling noise under the dash and the car was dying. Searched and asked arounf and everyone said main relay. Well I just swapped the relay and nothing. Fuel pump primes car kinda started once and then the same poping noise then it died. Are there vital grounds under the dash? Where are they, what else can I check? thanks
Old Nov 30, 2003 | 03:39 PM
ekb18cCivic's Avatar
Default Re: Car wont start!!!! (lonefuzzy79)
any CEL's????
Old Dec 3, 2003 | 12:59 PM
Default Re: Car wont start!!!! (ekb18cCivic)
only the ones that are telling me that my 02 isn't working but I have been driving around like that for quite some time now. There is something else afoot here help!!!
Old Dec 8, 2003 | 10:56 AM
ok now this is weird. After two weeks of not starting and acting the same after I replaced the main replay I come out and try to start the car and voila, it starts. Only todays its dry, no rain after weekes of rain. So I think moisture in something? But just to be sure I un plug the fuse box and check everything over and its all jake. Now what? Everything seems to plugged in fin, no corrosion, grounds and conected...I dunno what to do...thoughts? however since I unhooked the fuse box the SRS light is on, do I need to reset the ECU to reset the SRS (airbags)?
4doorpowa
24
Jan 24, 2023 04:36 PM
olschool92
Jul 25, 2011 02:38 PM
biggee
Jul 4, 2007 11:04 PM
Adam West
Jul 27, 2005 07:16 AM
DIYMIKE
Jan 30, 2005 09:39 AM
