Grinding 5th
Old Nov 30, 2003 | 02:58 PM
boobs's Avatar
Default Grinding 5th
box grinds going into 5th.
jst got a brand new 5 speed gearbox on my 94 h22a accord.
Any ideas on wat would make it grind up so early in its life???
its got new clutch, and all fluid levels are good outside as well as inside the gearbox.
grinds when going into gear over 140km/hr but not before...
Old Nov 30, 2003 | 03:33 PM
jweller's Avatar
Default Re: Grinding 5th (*****)
misaligned shifter fork. there is a TSB for it on all the f series trannies (except the f20c)
Old Nov 30, 2003 | 07:11 PM
boobs's Avatar
so wat does that exactly mean. is that the fork thats on the gearbox or the shifter in the car???
what should i do to fix the problem?
Old Dec 1, 2003 | 10:53 AM
skabone's Avatar
I've got that same problem on my 6th gen. I've got about 97,000miles and it only grinds in 5th.
Old Dec 1, 2003 | 11:00 AM
Spartanic's Avatar
If there is a problem in the tranny then you'll have to have a certified auto tech take a look at it because its real easy to mess things up. The Honda tranny cases can easily crack from just taking off the small 10mm bolts! I know becuase it happend to a friend. Anyhow did you let the tranny break in first before doing any hard driving? A new tranny requires at leat 1000 miles of regular driving before you start to drive more aggressive. If you don't do that and you start pounding on it then don't expect it to last very long.
Old Dec 1, 2003 | 12:44 PM
TypeSH's Avatar
Default Re: Grinding 5th (Spartanic)
its a common problem. it doesnt only happen to those who drive hard, bad design. There's a TSB w/ repair info on it online somewhere.
Old Dec 1, 2003 | 08:17 PM
boobs's Avatar
Default Re: Grinding 5th (TypeSH)
i dont drive it that hard. just started grinding up after about 4,000kms on it.
ill take it bak and get it fixed i guess. its a manual tranny by the way...
Old Dec 1, 2003 | 08:18 PM
boobs's Avatar
bquillin
Honda Civic (2001 - 2005)
Jul 10, 2008 07:54 AM
Mike1995HondaPrelude
Sep 18, 2007 06:21 PM
tcontesh
Jan 30, 2006 12:37 PM
Jeff
Apr 12, 2005 07:44 PM
