wiring spal window kit
It should have come with a wiring diagram.. It's pretty simple. All you need to do is run a power source and ground. The rest of it plugs into itself. The SPAL kits are cheap as hell, both of mine broke after 8 months. I'm going OEM
the spal kit only has 2 wires, one for up and one for down. the rest is ran off of the wiring harness for the stock switches, which go to power and ground.
