excessive fuel consumption
Old Sep 16, 2001 | 12:15 PM
dra_phantom's Avatar
New User
Default excessive fuel consumption
my 1988 civic 1.6i european model with a 1.6 sohc engine has excessive fuel consumption i've tried everything i need help it only does 308km on a full tank of gas and the valves started making some noise afterwards
Old Sep 16, 2001 | 03:29 PM
Aussie_ITR-0239's Avatar
New User
Default Re: excessive fuel consumption (dra_phantom)
Back off on the 'loud' peddle....
Seriously though, when you say "I've tried everything"....that means you've taken it to a Honda mechanic and had it checked out, right?!
Old Sep 16, 2001 | 03:59 PM
88_SC_CRX_Si's Avatar
New User
Default Re: excessive fuel consumption (Aussie_ITR-0239)
Is it throwing any kind of error/codes?
What color are your plugs when you pull them?
Do you smell gas/fuel from the exhaust, or see any kind of smoke out of the tail pipe?
When was the last time the fuel pressure regulator was checked, to see if it's still putting out the proper psi?
When you say you have replaced everything, does that include the air filter?
Old Sep 17, 2001 | 01:10 AM
New User
in nigeria we don't have honda repair centres just general mechanics who fix cars thru trial and error
Old Sep 17, 2001 | 01:56 AM
New User
Default Re: excessive fuel consumption (88_SC_CRX_Si)
i have'nt checked the fuel pressure regulator and i have no idea where it is
Old Sep 17, 2001 | 05:27 AM
SOHCArchangel's Avatar
try new plugs, cap and rotor, and look to see if there is excessive dust in the intake, are you near dry/dusty/desert?
Old Sep 17, 2001 | 03:18 PM
New User
It sets on the left hand side of the fuel rail. Has two lines going to it, one little one and one big one. The little one plugs into the intake manifold and is a vacuum line. The other one is the return line for the fuel.
You need to hook a fuel pressure gauge up to it, to see if it's within spec. Call around to some of the shops, you mentioned and see if they can check it for you. Usually when they go bad, to much fuel pressure builds in the system, causing the a rich condition.
[Modified by 88_SC_CRX_Si, 4:26 PM 9/17/2001]
mudpuppy4life
Jan 31, 2015 07:34 AM
*DRE*
Oct 4, 2011 11:13 PM
Maple50175
Jul 13, 2010 02:12 PM
craftysince86
Apr 24, 2006 04:39 PM
duh blacksheep
Aug 13, 2005 12:43 AM
