NEED to buy!!! Adjustable cam gear bolts
I recently purchased some toda adjustable cam gears and one of them is missing three of the adjustable timing bolts. I belive any bolt from AEM, skunk2, or any other cam gear will fit. So if any body as some extra cam gears bolts just lying around...I could really use some of the bolts
You can probably get them from the local hardware store.
They're probably M6x1.00 bolts. Let me check the set we have in the box and I'll get back with you.
They're M6x1.00. I measured them to be 14mm long (including the flanged portion of the head), but you might be able to get away with using a 16mm long unflanged bolt with washer and lock washer b/c a lot of times they don't make them in 14mm length. I've never seen them in that length at our hardware store.
I just went to the hardware store to get a set b/c I decided to change them over to hex head bolts on the Toda cam gears that John's using on his motor.
I had to get M6x1.00x12mm flange bolts b/c using a 12mm hex head bolt with a lock washer and washer would be a bit short, and using the 16mm long bolts was way too long. Long enough to scrape the rear upper timing belt cover.
P.S. Get the grade 10 stuff.
Modified by IN VTEC at 12:01 AM 12/4/2003
i know...dont rub it in. But I figure I didnt waste any money on gas going to the hardware store and then I know that they are ment for the cam gears
civicandr6
Feb 3, 2005 04:59 PM
