will a 35 offset fit a 5th gen?
5gen bolt pattern is 5x114.3 (4.5"). Also, 35mm offset will make the wheel stick out a lot; 55 is stock. You'd be better off between stock and 45 or so. A wider track will make your car handle a little slower and probably increase bearing wear.
In one word NO. The pattern for a stock rim is 5x114.3 +55 Offset.
If you plan to lower the car-absolutely not. This assumes you do not intend to do any serious flaring of the fenders. A 16x7 rim with +42 offset just clears on our 99 lowered on Neuspeed Sport springs and a full Camber kit.
xunkn0vvnx
Sep 14, 2002 08:21 AM
