GSR AEM V2 fit my ITR?
Old Nov 30, 2003 | 01:57 AM
douglas_be's Avatar
Default Will a AEM V-2 for work my Integra type R ??
Whos has tested the V-2 system on the Integra type R , is it worth the money ? Any one DYNOED THE V-2 CAI ?
I would use it for track racing on a Sleved B18C1 2.0liter engine.
Wher to order ?
Thanks for the reply
Modified by douglas_be at 11:25 AM 11/30/2003
Old Nov 30, 2003 | 06:44 AM
Kendall's Avatar
I've not used the system, but I'm pretty sure that the throttle body of the ITR and the GSR are located differently and that an aftermarket intake for one wouldn't fit the other, unless of course you switched to an aftermarket intake manifold such as the AEBS or the Skunk2, or perhaps got the ITR manifold.
Old Nov 30, 2003 | 06:57 AM
B2FiNiTY's Avatar
Default Re: Will a AEM V-2 for work my Integra type R ?? (douglas_be)
It will not fit.
If your GSR motor has the stock intake manifold then it will otherwise if you upgraded to skunk2 or itr it will not fit.
Old Nov 30, 2003 | 07:18 AM
Kendall's Avatar
The AEBS manifold actually made 1 or 2 horses more than the ITR one and it only costs like $169 so it would be a very cost effective upgrade, more so than an intake. And they have those plastic intake manifold gaskets that help to reduce heat in the intake manifold and make like 6 horses at the wheels (with just a gasket), they sell for like $69. And then you can get the Spoon throttle body and make even more power. I've just got an AEM cold air that's sawed off so that it's longer than the short ram but doesn't bend down like the cold air, I'm impressed with it.
Old Nov 30, 2003 | 07:45 AM
douglas_be's Avatar
Default Re: (dc231)
Hi,
I now have a ITR with a modified OEM airbox, I've cut off the airfilter and replaced it with an KN one , then I hooked up an 4 inck orange silicon hose to it that pick up air netx to the radiator. I hat an JG intake with an STR 70mm T/B. Now I am building a new engine and will be using a AEBS typhoon IM and wanted to use an AEM V-2 CAI so it would look clean , but will it fit and will it be better than my current modified airfilter ?
Old Nov 30, 2003 | 08:10 AM
Kendall's Avatar
Yes it should fit, but I can't justify spending the extra cash on the V2 versus the original, an imitation, or a good homemade one.
Old Nov 30, 2003 | 08:22 AM
vteckiller's Avatar
Default Re: (dc231)
no it wont fit diff tb
Old Nov 30, 2003 | 09:20 AM
itr1244's Avatar
Default Re: (dc231)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dc231 &raquo;</TD></TR><TR><TD CLASS="quote">I've not used the system, but I'm pretty sure that the throttle body of the ITR and the GSR are located differently and that an aftermarket intake for one wouldn't fit the other, unless of course you switched to an aftermarket intake manifold such as the AEBS or the Skunk2, or perhaps got the ITR manifold.</TD></TR></TABLE>
they are located NOT differently.. they are just different size.
you need 3" diamiter ..
Old Nov 30, 2003 | 09:31 AM
Kendall's Avatar
Stupid me, forgot about the 3" diameter, smack me please.
Old Nov 30, 2003 | 09:45 AM
riceburnah's Avatar
Default Re: (dc231)
umm..no it will not fit
Old Nov 30, 2003 | 09:48 AM
douglas_be's Avatar
Default Re: (ihaterice8)
YES or NO ? My wife decided quicker on our wedding day !!
be18see1
Sep 12, 2006 05:20 PM
acuraqc
Jan 21, 2004 12:34 PM
whitemike1644
Aug 25, 2003 08:12 AM
LOwrestling2001
Mar 5, 2002 08:00 AM
GsrSdn
Feb 9, 2002 08:59 AM
