jdm P73 ecu and differneces in them from year to year???
I want to know If there were any difference in the jdm itr p73 ecu's. Is one better then the other?? Is there two type. One has a blank slot with no pins and the other has all the slots on the ecu full of pin??
just make sure you have a right year ecu for your car. 96-8 are different from 99-01 ITR ecus as far as plug and pin location.
I persoanlly would run a OBDI ecu with harness converter or a stock USDM ITR ecu.
RedheadRacing
Sep 10, 2002 07:27 AM
