1982 Accord cold start *HELP*
Old Nov 29, 2003 | 02:32 PM
bigfatal's Avatar
Default 1982 Accord cold start *HELP*
New to this group, hope to be able to help some as time goes on. I'll try to keep this short and still post what I need to.
I just bought an '82 Accord for my daughter, who will be getting her DL soon. The car was "stored" outside for the last 1 1/2 years, but it was a STEAL - 76,000 original miles, one owner! Bought a new battery, replaced all fluids, and it ran rough but OK for 2 tanks of gas. Got a Factory manual so I could work on it. Had to replace the vacuum booster and master cylinder (not much room to pull the booster, but got it done). No problem.
Cleaned the Keihin 3 bbl carb & choke really well, pulled the plugs (which looked almost new) and re-gapped them to spec (1.1mm), timed the engine to spec (16 degrees BTDC). All wires ohmed out at ~ 10 k.
On cold start, it has to have the gas pumped about 3 times before it will start, then seems to be hitting on 3 cyls for about a minute or so - then revs to around 2k - takes a long tme for the choke pull off to work. After it's warm, it runs well, but at idle the is an occasional miss.
Anyone got an idea? Thanks in advance.
lurchy
Jan 22, 2013 09:14 PM
Vinceg99
Jan 27, 2010 09:24 AM
gerhard
Dec 7, 2007 03:00 PM
SoCal90Accord
May 29, 2004 10:02 PM
