Easy DIY Sound absorbing install
So my girlfriend was complaing about my exhaust being "too loud", wtf?! So after getting **** for months for it, I decided to do somthing about it. I ordered some Dynamat off ebay for a killer price, but the **** is fawkin heavy!!!!! So pondered on a cheap, lighter substitute. I remembered in my dorm room days I used some egg crate to line my door on the inside, to keep the noise down on those days I slept all day. SO here is what I came up with.
Step 1:
Remove the cardboard piece from the floor of your trunk\hatch and take it inside.
Step 2:
Take your eggcrate foam and cut it to the size of the cardboard piece.
Step 3:
Take some normal white glue or somthing similar and squrt it all over one side of the board (pref. the bottom of the board) & apply the egg crate to the board.
Step 4:
After it drys for a hour or so then put it back in the trunk\hatch.
This basically cut out the suspension noise and exhaust noise. Basically muffling all noise.
Good Luck!
smoke weed every day
Modified by greebler at 6:51 PM 11/29/2003
Step 1:
Step 2:
Step 3:
Step 4:
Good Luck!
i'm not sure if that'd work fo me tho...the vibrations traverse down the b-pipe and vibrate alot near the catalytic converter....so alot of the sound comes out through the center console
The best thing to do, which is what I'm doing for my stereo installs now...is to use something like dynamat, b-quiet, peel and seal, cascade etc to stop the resonance and vibration in the metal, and then an accoustical absorbing foam...any foam will do actually.
Of you can just do foam...it weighs virtually nothing. Might as well do under all your paneling.
My Civic sounds like a Lexus inside
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by greebler »</TD></TR><TR><TD CLASS="quote">smoke weed every day
some people will just skip to this step
</TD></TR></TABLE>some people will just skip to this step
In the past I've just used the eggcrate foam that you can buy at like walmart to put under your mattress and what not.
Some of the cars have had it in there for 5+ years and it's still holding up. I was a bit scared that it wouldn't hold up good in that kind of environment, but it is.
You could get the expensive stuff that's more durable, but i don't see why.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ridnmyhonda »</TD></TR><TR><TD CLASS="quote">just make your girl deal with it</TD></TR></TABLE>
I will assume you have never dated a Korean girl before..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmintegra1994 »</TD></TR><TR><TD CLASS="quote">i'm not sure if that'd work fo me tho...the vibrations traverse down the b-pipe and vibrate alot near the catalytic converter....so alot of the sound comes out through the center console
Yea I have some pieces left over from dynamating my doors that I will be putting around the shifter\ebrake cables. Your right, most of it comes from there.
</TD></TR></TABLE>Yea I have some pieces left over from dynamating my doors that I will be putting around the shifter\ebrake cables. Your right, most of it comes from there.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jonathan_EH »</TD></TR><TR><TD CLASS="quote">In the past I've just used the eggcrate foam that you can buy at like walmart to put under your mattress and what not.
I wouldn't spend more than $10, there is always that foam padding that is used to pad under your house's carpet. That can be purchased @ Home Depot or somthing like that.
hahahahahahaha.. sounds like a good idea though!
</TD></TR></TABLE>hahahahahahaha.. sounds like a good idea though!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by greebler »</TD></TR><TR><TD CLASS="quote">Installed
What it looks like
Yep, that's the same stuff I use.
Now take some spray adhesive and stick that to the back side of all your rear hatch paneling, and you've got it made
I'll try to get some pics up of my interior soon.
What it looks like
</TD></TR></TABLE>Yep, that's the same stuff I use.
Well my family owns a chicken farm out in east texas. We have huge rolls of this **** for the eggs back in yonder barn. Ya'll! LOL
jk
Go out to your local Walmart\Discount type store and go into the bedding dept.
jk
I did this to my coupe, and also stuffed the panels next to the back seat with eggcrate, and around the rear wheel wells. It muffles exhaust noise and road noise nicely. Now I can hear my engine better
Last time I stripped the back of my car, I stuffed about 10-15 lbs of polyfill into the sides of my car, from behind the front seats all the way to the back is full of polyfill. I should try this eggcrate stuff for some other parts, cuz my tires are getting to be pretty loud at 40 mph.
These are ES100's nearing the end of their life w/ 20K miles on them.
: Its worth doing, IMO.
