Anyone in NOVA with Mugen Lowdowns want to take me for a ride?
Old Nov 29, 2003 | 08:37 AM
BlackThorN's Avatar
Default anyone in NOVA with Mugen Lowdowns want to take me for a ride?
I'm thinking of buying them and I want to know if there's anyone in the NOVA area that will take me for a ride asap
please respond
thanks
Nick
Old Nov 29, 2003 | 09:21 AM
Hybrid 350GT's Avatar
Default Re: anyone in NOVA with Mugen Lowdowns want to take me for a ride? (BlackThorN)
Can't give you a ride since I am in San Diego, but for what its worth, I love mine. Ride is solid.
Old Nov 29, 2003 | 09:46 AM
Mugen Mike's Avatar
Default Re: anyone in NOVA with Mugen Lowdowns want to take me for a ride? (DOSPOWND)
Can't give you a ride since I am in Milwaukee, but for what its worth, I love mine.
Old Nov 29, 2003 | 11:15 AM
BlackThorN's Avatar
I do appreciate the thought, now hopefully someone in VA will take me for a ride
btw is it alot rougher then stock ITR or what?
Old Nov 29, 2003 | 11:22 AM
Default Re: (BlackThorN)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlackThorN &raquo;</TD></TR><TR><TD CLASS="quote">I do appreciate the thought, now hopefully someone in VA will take me for a ride
btw is it alot rougher then stock ITR or what?</TD></TR></TABLE>
It is rougher than stock ITR.
Old Nov 29, 2003 | 11:38 AM
BlueR's Avatar
Default Re: (DOSPOWND)
somebody give the man a ride so he can buy a set
Old Nov 30, 2003 | 09:12 AM
AamirCWITR's Avatar
Default Re: (BlueR)
Does anyone know the spring rate on the Low Downs?
Old Nov 30, 2003 | 10:05 AM
kkim's Avatar
Default Re: (AamirCWITR)
Courtesy of Arren123...
Here's the information I have from my research when I was buying the lowdowns.
Spring Rates - Mugen
Front – 385 lb 6.8 kg/mm
Rear – 245 lb 4.5 kg/mm
Spring Rates – Stock
Front – 246 lb /in
Rear – 140 ~246 lbs/in
Stock rates converted to kg/mm
Front – 4.4 kg/mm
Rear – 2.5 ~ 4.4 kg/mm
1 kg = 2.20462 lbs
1 mm = 0.0393701 inchs
conversion factor = 55.997317
Old Nov 30, 2003 | 10:44 AM
AamirCWITR's Avatar
Default Re: (kkim)
Personally, I would rather buy a full coilover set considering there does not seem to be much of a difference between stock and the low downs. You can obtain similar spring rates just by installing H&R or Eibach springs with bilstiens. And I am sure that would cost less than the lowdowns.
Old Nov 30, 2003 | 11:17 AM
bus stop's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DOSPOWND &raquo;</TD></TR><TR><TD CLASS="quote">It is rougher than stock ITR.</TD></TR></TABLE>
I don't think it is rougher than stock.....instead I will say the Lowdowns give you a more SOLID ride than stock, and the adjustment on the shock can give you something to play with in the local autoX
Old Nov 30, 2003 | 12:29 PM
BlueR's Avatar
Default Re: (WhosITR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WhosITR &raquo;</TD></TR><TR><TD CLASS="quote">
I don't think it is rougher than stock.....instead I will say the Lowdowns give you a more SOLID ride than stock, and the adjustment on the shock can give you something to play with in the local autoX </TD></TR></TABLE>
exactly...i would say the lowdowns are more of an extension of the stock susp...
where the stock setup ends, the lowdowns pick right up and go from there...
it was a very smooth transition going from stock to the lowdowns...
seemed very intuitive and natural...
Old Nov 30, 2003 | 01:46 PM
BlackThorN's Avatar
no offence to you but I didn't ask your opinion, nor is this thread asking for your opinion. I was asking for a ride in a car with them. I do appreciate everyone else's input on the ride they provide, however tellign me to buy a completely different set does seem a bit offtopic
we could discuss other matched spring and shock sets until the cows come home
please stay on topic
thanks
Nick
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AamirCWITR &raquo;</TD></TR><TR><TD CLASS="quote">Personally, I would rather buy a full coilover set considering there does not seem to be much of a difference between stock and the low downs. You can obtain similar spring rates just by installing H&R or Eibach springs with bilstiens. And I am sure that would cost less than the lowdowns. </TD></TR></TABLE>
Old Nov 30, 2003 | 01:53 PM
Misfit's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlackThorN &raquo;</TD></TR><TR><TD CLASS="quote">no offence to you but I didn't ask your opinion, nor is this thread asking for your opinion. I was asking for a ride in a car with them. I do appreciate everyone else's input on the ride they provide, however tellign me to buy a completely different set does seem a bit offtopic
thanks
Nick
</TD></TR></TABLE>I am sure aamir was just trying to help you out. I guess this holiday season is driving everyone nuts.
Old Nov 30, 2003 | 01:54 PM
BlackThorN's Avatar
I actually spent 4 hours helping my dad make a deal for the new TL with nav and full body kit just now....mabye I am a bit tense
Old Nov 30, 2003 | 01:56 PM
Misfit's Avatar
No probs.... I am sure the Mugen lowdowns are butter.. If you have the money I am sure they are worth it. Good luck
ITR 05082
Nov 25, 2007 07:17 AM
mcdull123
Aug 19, 2007 10:56 AM
norice
May 8, 2005 12:01 PM
Tommy_Gunns
Apr 25, 2004 01:19 PM
RaVAGE00
Aug 14, 2001 08:11 PM
