anybody know about a awd civic wagon?
Old Sep 16, 2001 | 12:17 AM
greyshark's Avatar
New User
Default anybody know about a awd civic wagon?
i was wondering , i seem to remember a awd civic wagon from about 91. if it is true wouldnt it make a cool racer. a wagon hookin up at the light to beat a mustang.
Old Sep 16, 2001 | 01:43 AM
max's Avatar
max
Default Re: anybody know about a awd civic wagon? (greyshark)
ur nuts, man
Old Sep 16, 2001 | 07:10 AM
eg6ajk's Avatar
the problem with the wagon is its weak drivetrain, especially the 4wd system plus the heavy weight....
but a ZC DOHC is a boltin and good enough for the car on the street
in japan they used to have 4wd sedan civics and 4wd integras, which came with DOHC ZCs
Old Sep 16, 2001 | 04:37 PM
91ED7Si's Avatar
Default Re: anybody know about a awd civic wagon? (eg6ajk)
i know a guy with a 91 rt..
hes got a custom exhaust and tsw imolas..
it looks really ****** clean
Old Sep 16, 2001 | 06:55 PM
rioninja's Avatar
Default Re: anybody know about a awd civic wagon? (DOHC DX)
6 speed tranny... My friend just did a sohc vtec in his CRX. I wonder if that would bolt into the rex, sans the rear drivetrain. Anyone ever take a good look at it?
Old Sep 16, 2001 | 07:07 PM
91ED7Si's Avatar
Default Re: anybody know about a awd civic wagon? (RioNinja)
its geared for **** and its weak..
i dont think you can use it w/o awd either..
Old Sep 16, 2001 | 07:17 PM
Gasoline Fumes's Avatar
It's a 5 speed with "Super low." A gear lower than 1st. Super low wouldn't really have much benefit for high performance street use.
The 1985 4WD Wagons had a button to engage 4WD. The 1986-87 had a full time viscous coupling. Both with a solid rear axle and the 1.5l carbureted engine.
The 1988-91 Wagons had the same viscous coupling, but with independent rear suspension. And the 1.6l CRX Si engine.
[Modified by Gasoline Fumes, 4:19 AM 9/17/2001]
Old Sep 16, 2001 | 11:35 PM
greyshark's Avatar
New User
Default Re: anybody know about a awd civic wagon? (Gasoline Fumes)
thanx guys what i was wondering is what about a frankinstein awd dohc vtec crx would that be tite or what
Old Sep 17, 2001 | 02:51 AM
thefungus's Avatar
New User
fumes knows his ****.
-fungus tips his hat
Old Sep 17, 2001 | 07:26 PM
Default Re: anybody know about a awd civic wagon? (theFungusAmongus)
Thanks, fungus.
Old Sep 18, 2001 | 09:53 AM
kahren's Avatar
yes i had taht idea, bu ti though i shoudl leave wagons alone after i drove an SUV....
i reccomend u do the same
Old Sep 18, 2001 | 11:01 AM
gutted spec's Avatar
New User
Default Re: anybody know about a awd civic wagon? (kahren)
Back in my d-series days, I'd always dreamt of that 5 speed super low tranny with a taller final. If it's a stock 4.25 final, throw in the dx 3.88. Or if it's lower...try another lower final. Then that first gear will run to, say, 20mph...and just rip. But the whole awd system is weak and can't support extra power, so I'm guessing the tranny is similar.
Old Sep 18, 2001 | 11:27 AM
frank5079's Avatar
I stumbled across an '85 AWD wagon last week in the junkyard; aside from missing head, its in pretty good shape inside and out. If the price is right, I'd like to get the whole thing and do a teg swap to it........
Old Sep 18, 2001 | 11:46 AM
max's Avatar
max
Default Re: anybody know about a awd civic wagon? (frank5079)
so do it
Old Apr 21, 2003 | 12:27 PM
kyle h.'s Avatar
Default Re: anybody know about a awd civic wagon? (max)
everyone always says the drivetrain is so weak...but never backs it up with any proof...
Old Apr 21, 2003 | 02:01 PM
SleeprCrx's Avatar
Default Re: anybody know about a awd civic wagon? (kyle h.)
find a awd manual crv and and try to swap all that good ol' b series stuff over to it... otherwise go zc turbo in that awd thing and see how it feels... i think there's a guy in this board that has done awd zc turbo...
Old Apr 21, 2003 | 04:06 PM
SoyRacer's Avatar
Default Re: anybody know about a awd civic wagon? (SleeprCrx)
Read Below
Old Apr 22, 2003 | 06:45 AM
altoid's Avatar
Default Re: anybody know about a awd civic wagon? (SoyRacer)
go to the links in my sig. Its hella short gearing. blah blah whatever.
http://honda-civic-wagon.cjb.net/
Old Apr 22, 2003 | 07:17 AM
talonmm's Avatar
thats crazy
Old Apr 22, 2003 | 07:22 AM
altoid's Avatar
Default Re: anybody know about a awd civic wagon? (gutted spec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gutted spec &raquo;</TD></TR><TR><TD CLASS="quote">Back in my d-series days, I'd always dreamt of that 5 speed super low tranny with a taller final. If it's a stock 4.25 final, throw in the dx 3.88. Or if it's lower...try another lower final. Then that first gear will run to, say, 20mph...and just rip. But the whole awd system is weak and can't support extra power, so I'm guessing the tranny is similar.</TD></TR></TABLE>
tranny is stronger than the 2wd counterparts. the whole thing is just like the rest of 4th gen civics can't hold much more than 225 hp anywhere w/out upgrades
SL 4.512 1st 3.384 2nd 1.950 3rd 1.275 4th 0.941 5th 0.783 reduction ratio(transfer case gear) 4.428
Modified by altoid at 12:46 PM 4/22/2003
Old Apr 29, 2003 | 06:51 PM
civicwagonman's Avatar
Default Re: anybody know about a awd civic wagon? (altoid)
nothing in the transmission will interchange with other d-series trans, except maybe a zc trans. it uses bigger axles and internals like b18 stuff(been there tried that). the weak point is the transfer case and the rear diff, but mine works great doggin it on 6-7lbs of boost.
I ate up my friends 90 mustang.
EKCRX-Ihadastupidusername
Nov 16, 2005 06:49 PM
.jacob
Feb 8, 2004 10:29 AM
RussHondaCRXVtec
Sep 26, 2003 12:19 AM
EG6owner-T
Jan 30, 2003 08:31 PM
