JDM itr axles in gsr tranny??
Old Nov 28, 2003 | 11:29 PM
tyflip2's Avatar
Default JDM itr axles in gsr tranny??
will jdm itr axles fit into a jdm gsr tranny. i heard that the axles are a little bit bigger and wont fit but i want to make sure. thanks alot
Old Nov 29, 2003 | 07:23 AM
ill phil's Avatar
Default Re: JDM itr axles in gsr tranny?? (tyflip2)
Yes, they will fit. The side that mates to the tranny is the same as USDM (32mm), the hub side is 36mm. Which may cause a problem if you don't have JDM 5-lug.
Old Nov 29, 2003 | 08:15 AM
tyflip2's Avatar
Default Re: JDM itr axles in gsr tranny?? (ill phil)
does anyone else have any input. i need some more opinions before i take my car apart
Old Nov 29, 2003 | 08:18 AM
ill phil's Avatar
It's not an opinion, if you don't believe me use the SEARCH function and see for yourself. Just look under JDM ITR axles.
Old Nov 29, 2003 | 08:31 AM
tyflip2's Avatar
alright thanks alot i believe you its just i was reading earlier that the jdm ones will not work since they are larger. thanks for the help though
Old Nov 29, 2003 | 08:51 AM
ill phil's Avatar
Heres a few links-
JDM ITR axles from 98-Up: 36mm outter, 32mm inner.
USDM axles- 32mm outter, 32mm inner.
https://honda-tech.com/zerothread?id=359382
https://honda-tech.com/zerothread?id=512005
https://honda-tech.com/zerothread?id=625366
You'll have better luck searching under JDM 5-Lug. But like I said earlier, if you don't have JDM 5 lug then the outter part of the JDM ITR axle won't match your hubs. If you have 4 lug, USDM ITR, CTR hubs you can use any B-series besides 90-93 Integra axles I do believe.
Old Nov 29, 2003 | 09:32 AM
tyflip2's Avatar
so will it not work on my ek with 4 lug in my gsr tranny. i dont want to change the lugs or anything i just need new axles. thanks for your help
Old Nov 29, 2003 | 09:45 AM
ill phil's Avatar
Did you just bust an axle or what? If its a JDM ITR axle with 36mm outter it will not fit in the 4 lug hub. The 4 lug hubs are 32mm. If you just need an axle go to autozone and take yours as a core and get a replacement for a GSR.
Old Nov 29, 2003 | 09:54 AM
tyflip2's Avatar
ok thanks alot
Old Nov 30, 2003 | 01:29 PM
AmauryR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tyflip2 &raquo;</TD></TR><TR><TD CLASS="quote">alright thanks alot i believe you its just i was reading earlier that the jdm ones will not work since they are larger. thanks for the help though</TD></TR></TABLE>
well, in order to use them, you'd need
A) '98+ jdm ITR 5-lug (to use the 36mm),
B) or swap hubs and find a 4x100 honda hub that uses 36mm axles (which I haven't found), or
C) possibly use 4x114 prelude front hubs and use the 36mm spline, (which I'm in the process of doing) axles.
like ill phil said, the inner joints will work (same as usdm), but the outer ones will need one of the solutions mentioned above.
PS. You can also try '98 lude axles (sh I belive), someone on here tried them and they work also (and have beefier inner & outer joints). But you'd still have that problem with the front hubs.
smiko0124
Dec 2, 2010 02:04 PM
2tonedc2
May 22, 2008 03:42 PM
Terrible One
Mar 19, 2005 06:19 AM
civicqm
Feb 19, 2004 12:39 AM
