using DSM injectors
Old Nov 28, 2003 | 11:08 PM
ScootinIntegra's Avatar
Default using DSM injectors
OK, before i get flamed for this, let me get it out of the way. I searched, found nothing.
Does anyone have a write-up on using the 450cc injectors in a B18b1? I know i need resistors, but honestly i can't remember whether we need to convert TO peak and hold or FROM peak and hold (to saturate). Maybe i'm just stupid.
So does anyone have any detailed instructions on this set up? i.e. with pictures?
Old Nov 28, 2003 | 11:30 PM
Hoodwinked's Avatar
Default Re: using DSM injectors (ScootinIntegra)
you need to convert from saturated to peak and hold. you can obtain a resistor box out of a 88-91 crx or something like that I beleive. check ebay, they have some there. the injectors should just pop right in, mine did, but I have heard some people had to bore it out a little to fit it.
Old Nov 28, 2003 | 11:35 PM
Default Re: using DSM injectors (Hoodwinked)
awesome, thanks.
So does anyone have any pictures or can anyone tell me how to wire up the injectors throught the resistor box?
Old Nov 29, 2003 | 02:28 AM
liam821's Avatar
little ghetto picture....
liam
Old Nov 29, 2003 | 04:20 AM
Killer_B's Avatar
using the resistor box is A LOT cleaner. look at my pic and notice the Honda plug that i used coming off the resistor box. it's the plug leaning on the Clutch fluid reservoir.
Old Nov 29, 2003 | 04:43 AM
Dr Honda's Avatar
Default Re: using DSM injectors (liam821)
Not that it realy matters, because liam821's write up will work, But...
The yellow and black wires are positive power, not grounds. The other colored wires from your injectors that lead down to the ECU are the grounds. In the electrical world... it's easyer to control a ground switch rather than the positive power switch. (it has somthing to do with a back EMF in a semi-conductor)
Just an FYI
I also recomend using a resistor box. They are cheap, and look like they were ment to be under the hood. I got mine from a prelude at the local junkyard for $3. If you go the junkyard route... take a multy meter with you so you can check to see if all 4 resistors are good. (one lead to the red or black wire, then check the other 4 yellow/black wires with the other. you shlould read 6 to 8 ohms.)
Good luck
Old Nov 29, 2003 | 04:51 AM
Boost2NA's Avatar
Default Re: using DSM injectors (Dr Honda)
good info guys. just what i was looking for
Old Nov 29, 2003 | 01:04 PM
liam821's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dr Honda &raquo;</TD></TR><TR><TD CLASS="quote">Not that it realy matters, because liam821's write up will work, But...
Just an FYI
Good luck</TD></TR></TABLE>
yea you are correct. that drawing is just old. It doesnt matter if its on the ground or the positive. both will work.
liam
Old Nov 29, 2003 | 01:13 PM
IntegracinGSR's Avatar
im also using the DSM 450's but i have one yellow/black wire and 4 red/black wires.. how do i hook this up?
Old Nov 29, 2003 | 01:22 PM
booscivic's Avatar
check under ladysman he did a really good write up on that!!!
Old Nov 29, 2003 | 03:03 PM
97F22B2's Avatar
Default Re: (booscivic)
You can also steal the resitor boxs out of Accords and Preludes, 5th gen accords have one i know of as well as 4th gen ludes.
Old Aug 12, 2006 | 11:38 AM
BLUE EH3's Avatar
Help we my pennies
Default Re: (97F22B2)
dsm stuff fits right it?
Old Mar 29, 2010 | 11:06 AM
hossein ali's Avatar
hi guys i want to reinstall the injectors but how???
and i have 96 civic sedan bye
thanks
Old Mar 29, 2010 | 11:52 AM
Schister66's Avatar
Man U FTW
That should help
Old Mar 25, 2011 | 12:11 PM
daluv's Avatar
bringing this back from the dead...
So, I just got my blue top DSM injectors for my OBD-1 boosted LS setup in my 94 hatch, and am getting ready to install them and get re-tunned, but I have a problem...
My stock Honda injector clips (the grey plugs that clip onto the injectors,) wont fit on the DSM injectors...? Am I supposed to be using DSM injector clips? The Honda clips start to fit, but wont go all the way over the dsm injectors.
Any help would be greately appreciated. Thanks in advance!
Old Mar 25, 2011 | 12:20 PM
daluv's Avatar
nevermind, I didnt notice that small sliver of blue plastic material within the DSM injector plug port near the connector pins that needed to be shaved off.
b16bri
Sep 5, 2010 02:53 PM
ironiceghatch
Feb 11, 2008 01:26 PM
Schister66
Apr 26, 2006 08:36 AM
sivik2nr
Jun 11, 2003 09:59 PM
