Eagle rod weight compared to stock GS-R?
Old Nov 28, 2003 | 10:31 PM
Dammit_Dan_954's Avatar
Default Eagle rod weight compared to stock GS-R?
How much do each of these rods weigh? Which is lighter? Should I buy eagle rods or just get the stock GS-R rods shot peened and use arp rod bolts?
Old Nov 29, 2003 | 12:53 AM
chris@allmotor.net's Avatar
Default Re: Eagle rod weight compared to stock GS-R? (FastAssEG)
they are about the same weight as the GSR's just are WAY beefier...weight isnt everything when it comes to parts
Old Nov 29, 2003 | 10:16 AM
Default Re: Eagle rod weight compared to stock GS-R? (One.allmotor DA)
thats funny i heard weight is everything ,and thats why eagle rods go in the trash.
Old Nov 29, 2003 | 04:51 PM
Default Re: Eagle rod weight compared to stock GS-R? (killerbseries)
Old Nov 30, 2003 | 11:07 AM
.derf.'s Avatar
whats up dan. the eagle rods work fine for me. if you plan on spraying still i would deff. go with the eagles. its going to cost you like $40 for the arp bolts then like another $50 to get them pressed in. then like $20-30 to get the pistons put on the stock rods. might as well spend the extra $150 and get some aftermarket rods
Old Nov 30, 2003 | 11:09 AM
Gravy's Avatar
for the price you cant go wrong with eagles. its better than having stock rods in there. and lighter is better when it comes to rotating assemblies.
Old Nov 30, 2003 | 11:18 AM
johnzm's Avatar
Default Re: Eagle rod weight compared to stock GS-R? (Gravy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Gravy &raquo;</TD></TR><TR><TD CLASS="quote">for the price you cant go wrong with eagles. its better than having stock rods in there. and lighter is better when it comes to rotating assemblies.</TD></TR></TABLE>
eagle rods are heavier than stock rods. so they must be worse
i am sticking with oe rods that are balanced and arp in them, since i want a light rotating assembly, and will be making under 250whp.
i did some research and it seems anything lighter than an oe rod is 1000+ a set
edo
35
Sep 4, 2005 06:45 PM
ActiveAero
24
Jan 14, 2004 10:27 AM
toooslow
Oct 9, 2003 04:16 PM
SSBP DC2
Jul 2, 2003 07:08 PM
schwett
Apr 24, 2002 10:43 PM
