Hone the H22a1 before dropping pistons?
Old Nov 28, 2003 | 09:18 PM
laughinxxx's Avatar
New User
Default Hone the H22a1 before dropping pistons?
Now I know that honing adds texture to the cylinder walls to help break in the rings. However, the Helm's says that it isn't necessary to hone the block unless there is enough scoring to catch a fingernail. So, do I pull the motor and hone the block or just drop the oil pan, check the cylinders, and toss the type S pistons in if everything checks out? TIA
Old Nov 29, 2003 | 09:33 AM
laughinxxx's Avatar
New User
Default Re: Hone the H22a1 before dropping pistons? (laughinxxx)
ttt
Old Nov 29, 2003 | 10:15 AM
HotWheelz's Avatar
i'ts not using standard stones....
special stones and paste must be used. your engine builder should contact his supplier they should know.. not just a g60 stone or what helms say.
Old Nov 29, 2003 | 10:25 AM
laughinxxx's Avatar
New User
Default Re: Hone the H22a1 before dropping pistons? (HotWheelz)
So the machine shop should be able to find out what to use once they know it's FRM?
Old Nov 29, 2003 | 11:04 AM
MAX_CFM's Avatar
Diamond Stone
I have one
Old Nov 29, 2003 | 11:09 AM
hotintegranights's Avatar
Default Re: Hone the H22a1 before dropping pistons? (MAX_CFM)
y dont you have the cylinder walls hone right at the shop when you have the pistons installed, this is very important for your rings to seal right.
Old Nov 29, 2003 | 11:18 AM
laughinxxx's Avatar
New User
Default Re: Hone the H22a1 before dropping pistons? (hotintegranights)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hotintegranights &raquo;</TD></TR><TR><TD CLASS="quote">y dont you have the cylinder walls hone right at the shop when you have the pistons installed, this is very important for your rings to seal right. </TD></TR></TABLE>
Because I'm putting this motor together myself.
seldon
11
Sep 17, 2008 04:42 PM
laughinxxx
Dec 2, 2003 05:57 AM
InsertCleverSN
Apr 27, 2003 06:41 PM
ZERO COOL
Mar 1, 2003 09:23 AM
