z6 into 89 std, engine harness wiring help needed
Old Nov 28, 2003 | 06:32 PM
SOHC_Brian's Avatar
Default z6 into 89 std, engine harness wiring help needed
i'm following write up on this page http://www.geocities.com/kurtsi_on/page8.html
and i have the obd0 to obd1 harness complete. when i went to wire up the engine harness, i found out my uncle threw away the obd0 engine harness when he put the z6 in, so i only have the obd0 harness from the ecu to the engine bay. i gonna need help on wiring up the injectors, distributer, and oxygen sensor. so far i wired up the brown, red, light blue, and yellow wires from the injectors to the ecu and need to know where to wire the yellow'black wire from each injector to (i'll connect the obd1 junction to this also) the instruction said to wire it from the old injector plugs but i don't have them. also i can't interchange the new distibuter plug with the old one since i don't have the old one, so i need to know where at the ecu to splice these seven wire from the distibuter plug to, and the 2 wire plug next to the distributer also. and i need help identifying which wires from the ecu goes to the oxygen sensor also. thanks for any info anyone could give me. and any tips on anything else i might of not done yet to complete the swap or any common errors someone might make.
-brian
Modified by lazyassbrian at 10:36 PM 11/28/2003
B18aef
Aug 16, 2016 06:02 PM
CRX91SE
Sep 18, 2010 03:06 PM
chrisfromsrq
Jan 22, 2010 12:52 PM
strtrcr77
Dec 5, 2009 09:45 AM
94EGKUSH
13
Feb 3, 2009 11:55 PM
