well i used no pcv
Old Nov 28, 2003 | 03:34 PM
b18c-93's Avatar
New User
Default well i used no pcv
well i went ahead and used no pcv valve and pluged the manifold and ran all my lines to the catch can and went for a test run and when i came back i already had oil in the catch can and why with the pcv i never had really much over time is that normal or is that a sign
Old Nov 28, 2003 | 04:09 PM
eyeamvic's Avatar
You're supposed to still have the pcv valve when using a catch can. Run a vacuum line from the PCV valve to the catch can and then one from the catchcan to the intake manifold.
Old Nov 28, 2003 | 04:33 PM
chad's Avatar
Moderator
Default Re: (eyeamvic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eyeamvic &raquo;</TD></TR><TR><TD CLASS="quote">You're supposed to still have the pcv valve when using a catch can. Run a vacuum line from the PCV valve to the catch can and then one from the catchcan to the intake manifold.</TD></TR></TABLE>
yes....
mastamind
Oct 4, 2006 02:36 PM
tasco
Aug 30, 2006 02:19 PM
jvonb
Nov 12, 2005 05:26 PM
JMinSi2000
Nov 4, 2004 09:33 AM
DaX
May 23, 2004 07:11 AM
