who has made their own downpipe?.......questions inside
Old Nov 28, 2003 | 10:01 AM
yusoslo's Avatar
Default who has made their own downpipe?.......questions inside
I have been welding for 5 months now and are pretty good, thing is I have a full turbo kit on my car with no down pipe. Would it be an ok idea to cut angles out of the 3" pipe and weld it back together because I dont have a mandrel bender. I would really only need a 45 and a 30 bend.
So basically has anyone done this before
Old Nov 28, 2003 | 10:06 AM
99B16Si's Avatar
first off, what kind of car is it? what kind of turbo position do u have? and why cant you just buy mandrel bends????? u dont need to bend the pipe yourself, they come pre-bent. also if u plan on keeping a/c a 3" DP is really hard to fabricate
Old Nov 28, 2003 | 10:18 AM
Flamenco-T's Avatar
Default Re: who has made their own downpipe?.......questions inside (yusoslo)
if you're using log style manifold liek revhard, drag, inline pro, you need to get it out of the turbine housing at 2.5" with standard U bends. You can fit a 3" all the way in, but you'll have to cut more at tighter angle to get it to fit with AC.
Why don't you buy u-bend ? You can get ANY angles from U-bend..
stan
Old Nov 28, 2003 | 10:51 AM
hulkhb's Avatar
Default Re: who has made their own downpipe?.......questions inside (Flamenco-T)
dont cut and weld alot of peices toge3ther that will look tacky with such a nice kit.
buy a U bend. 3" is about 25$
Old Nov 28, 2003 | 11:25 AM
scttydb411's Avatar
go to http://www.jcwhitney.com and buy to 3" L bends and cut/weld them...way better.
Old Nov 28, 2003 | 11:36 AM
Jockobo's Avatar
Default Re: (scttydb411)
thats what we did...
http://www.we-todd-did-racing....D.jpg
Old Nov 28, 2003 | 10:06 PM
yusoslo's Avatar
Default Re: (Jockobo)
My turbo kit is a drag gen 1 kit for the d16z6 engine. I didnt think that a 3" DP would work with the AC.
I guess i will have to see when i put the engine in.
BTW: I have to start with a 2.5 from the flange and then flare to a 3", is that correct????
My cat back is 2.5, so would a 3 in DP be pointless in spool up time?
Old Nov 28, 2003 | 10:07 PM
SiR Kid's Avatar
New User
Here's my 3" downpipe we made for my Civic... We had to cup up a 3" donut from Road Race Engineering and re-angle it every 90 degrees or so, because of space issues with the JimFab crossmember, but we didn't want to keep A/C so that was one hurdle out of the way...
It's REALLY complicated, and still to date hasn't been completed because the welder is not where the car is at, so it's a back and forth thing, and we're also fighting laziness isues, as well.
Old Nov 28, 2003 | 10:13 PM
bigwig's Avatar
This is along the same subject....when fabing a custom DP, can you use the same cuplers that you might use for your charge pipes? I mean clean the pipes...jb weld...and then a coupler...would that work for those of us who dont have a welder?
Old Nov 28, 2003 | 10:19 PM
TurboJesse
Guest
Posts: n/a
Default Re: (bigwig)
um dp's get ALOT hotter than charge piping, i dont' think they would have a problem melting couplers..
Old Nov 28, 2003 | 10:20 PM
Tad's Avatar
Tad
looks good
Old Nov 28, 2003 | 11:04 PM
Evil EG's Avatar
Default Re: (Mpir3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mpir3 &raquo;</TD></TR><TR><TD CLASS="quote">um dp's get ALOT hotter than charge piping, i dont' think they would have a problem melting couplers..</TD></TR></TABLE>
Yeah a dp would definatly melt a coupler in no time.
Old Nov 29, 2003 | 08:21 AM
Ri5e's Avatar
Default Re: (BVM)
Most silicone couplers start getting mushy at around 300 degrees farenheit so, yeah, I don't think you want to use it on a 1,000 degrees+ downpipe
Old Nov 29, 2003 | 08:30 AM
SIXTYdashONE's Avatar
HT's Biggest Loser
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bigwig &raquo;</TD></TR><TR><TD CLASS="quote">This is along the same subject....when fabing a custom DP, can you use the same cuplers that you might use for your charge pipes? I mean clean the pipes...jb weld...and then a coupler...would that work for those of us who dont have a welder?</TD></TR></TABLE>
You gotta be kiddin me..
Old Nov 29, 2003 | 08:38 AM
Rhman19's Avatar
Default Re: (SIXTYdashONE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIXTYdashONE &raquo;</TD></TR><TR><TD CLASS="quote">
You gotta be kiddin me..</TD></TR></TABLE>
Just smile and nod. Of course you can do that.
Old Nov 29, 2003 | 09:07 AM
yusoslo's Avatar
Default Re: (Rhman19)
That downpipe looks good, as do your welds.. Where did you pick up that donut??
Old Nov 29, 2003 | 12:55 PM
TurboR1391's Avatar
Things that make you go hmmmm! <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bigwig &raquo;</TD></TR><TR><TD CLASS="quote">This is along the same subject....when fabing a custom DP, can you use the same cuplers that you might use for your charge pipes? I mean clean the pipes...jb weld...and then a coupler...would that work for those of us who dont have a welder?</TD></TR></TABLE>
Old Nov 29, 2003 | 07:43 PM
bigwig's Avatar
it was just a though...i honestly didnt know the temp going to your charge pipes was that big of a difference between the temp going down your DP....i was just trying to think of a way to craft a DP for those of us who dont have welders and dont want to spend $100-150 to have some muffler shop do a half assed job...
Old Nov 29, 2003 | 07:48 PM
bretx0r's Avatar
theres a big difference
Old Nov 29, 2003 | 07:52 PM
Ri5e's Avatar
Default Re: (bretx0r)
If you wanna save money, what you can do is cut up the pipes and line them up so that it makes the shape that you desire. Then use a marker and make marks so that when you take it to the welding shop, they will know exactly where to weld. It shouldn't cost more than $70 to weld 3-5 spots
Old Nov 29, 2003 | 08:13 PM
HT's Biggest Loser
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bigwig &raquo;</TD></TR><TR><TD CLASS="quote">i dont want to spend $100-150 to have some muffler shop do a half assed job...</TD></TR></TABLE>
And you think putting silicone couplers on burning metal isnt half-assed? what in gods name are you smokin. Not to be a dick, but in every single post, i see your trying to save money. Thats cool and all, but this isnt a cheap sport, try chess, thats cheap.
Old Nov 29, 2003 | 08:24 PM
spike's Avatar
you might be able to angle the first piece up a bit to give you more room to do a harder bend.. that's what we ended up doing on a CRX without the Jimfab bar.. we cut up a U Bend and angled it with 15 degree angles on each making it a tighter bend.. just an idea.
Old Nov 29, 2003 | 08:55 PM
dfoxengr's Avatar
Default Re: (SiR Kid)
i get it ...im retarded
Modified by hybridvteceg at 4:23 AM 11/30/2003
Old Nov 29, 2003 | 09:07 PM
yusoslo's Avatar
Default Re: (hybridvteceg)
haha, I am 99% sure that you cut up the donut to the desired angles that you want. essentially I would need a 45 and a couple 15 degree bends to make it come out good.
I can believe a shop would charge that much for welding, I can do it my self and plan to, plus it takes about 20 min to do. But luckly my friend has a welder.
Old Nov 29, 2003 | 09:58 PM
bigwig's Avatar
And you think putting silicone couplers on burning metal isnt half-assed? what in gods name are you smokin. Not to be a dick, but in every single post, i see your trying to save money. Thats cool and all, but this isnt a cheap sport, try chess, thats cheap.</TD></TR></TABLE>
This isnt meant to thread jack...but jesus christ...im sorry im not sponsored and blah blah blah...some ppl are looking for alternatives and ive seen numerous DP's done by a local muffler shop that have just gone to hell because the muffler shop sucks. The silicon was just an idea...some people are willing to think of alternative methods to get things done economically and challenging yourself to think of alternatives....
