IGNITION UPGRADE 92 Accord EX
Old Sep 15, 2001 | 04:21 PM
WIZARD's Avatar
New User
Default IGNITION UPGRADE 92 Accord EX
What's the best full ignition upgrade for a 92 Accord EX, (plugs, wires, etc.)? and do anyone use Ractive 9mm or nology wires ?
Old Sep 16, 2001 | 08:37 AM
SOHCArchangel's Avatar
Default Re: IGNITION UPGRADE 92 Accord EX (WIZARD)
if you want REAL ignition wires get magnecor wires, as for the rest i use an msd 6al and blaster ss coil with external coil conversion distributor from msd
Old Sep 18, 2001 | 08:50 AM
WIZARD's Avatar
New User
Default Re: IGNITION UPGRADE 92 Accord EX (SOHCkordVTEC)
I was told thet the Accords already have a REV limmit in the computer, so the MSD 6A sould be good enough. is this true ? Has anyone else used this before?
Old Sep 18, 2001 | 09:44 AM
the stock fuel cut is 6500, spark cut is 6250, with the 6al u put in like say a 7k rpm pill you increase your revrange to whenre the stock fuel cut is
Old Sep 18, 2001 | 03:28 PM
Gennady's Avatar
New User
Bosch Platinum +4 plugs
Phatbush Accords huh??
BENSONHURST BABY!!!
Old Sep 18, 2001 | 08:09 PM
90exaccordVA's Avatar
New User
Default Re: IGNITION UPGRADE 92 Accord EX (Wont be beat)
jacobs iCE pack ignition (has coil controle module, cap conversion, and wires, but dont buy directly from jacobs, they charge more than resellers, and if you call them they will give specific hp and fulemilage gains according to your mods) buts it costs around $400-450
Old Sep 19, 2001 | 10:21 AM
smokin rubber's Avatar
Default Re: IGNITION UPGRADE 92 Accord EX (90exaccordVA)
do you have the jacobs ign? how likely are the 8-10 hp gains they claim for a accord, I have seen these claims in the magazines. I think a horse or two at the wheels are more likely.
Old Sep 19, 2001 | 12:56 PM
m0t0rhead's Avatar
hmmm... If this is true, I wonder why my '97 5-spd revs to at least 7200 without cutoff.
I did not upgrade the ignition.
Old Sep 19, 2001 | 01:43 PM
4doorH22's Avatar
Default Re: IGNITION UPGRADE 92 Accord EX (Escobar)
Hmmm that is very strange.
Dyno test after dyno test show that the stock plug wires make the most power, followed by NGK, and the expensive wires like Nology at the bottom with power loss. Also, the plain old NGK V power (non-platinum) plugs from your Honda dealer are great. Platinum is more for longevity than performance and may gain you at most 1 horsey.
Old Sep 19, 2001 | 02:25 PM
CardDealer's Avatar
Banned
Default Re: IGNITION UPGRADE 92 Accord EX (4doorH22)
Modified by CardDealer at 4:20 AM 11/16/2006
Scott Little
Oct 27, 2015 12:22 PM
Hondero_PR
Sep 12, 2011 03:03 PM
Randee1677
Apr 4, 2008 04:59 AM
AMChev
Oct 16, 2002 04:47 PM
EminemGSR
Oct 26, 2001 09:36 AM
