What is this "sticky stuff" that come on a Stcok Integra?
Once you take out the inside door panels, you can see the door is covered with thin plastic sheet. Platic sheet is glued to the metal door with a sticky kind of a thing.
Anybody knows what is this stuff? Why the plastic sheets are there? Easy way to remove this sticky stuff?
Btw I have a 99 Integra
[Modified by bemathew, 4:19 PM 9/15/2001]
It's not a glue, but a kind of tacky putty that can be reused. If you need to access the inside of the door, just carefully pull off the plastic sheet, do whatever it is you need to do and then join the putty on the sheet with the stuff still left on the door. If it came off the door and stuck only to the sheet then just press down on the sheet to make it adhere to the door. It's pretty awesome stuff, totally reusuably and very sticky but removable as well.
I'd like to know where to buy the stuff though...
I am planning to put dynomat/Brown bread stuff on the door panels. What is the best way to do it?
Remove the plastic sheet, then put the dynomat stuff then put the plastic sheet again?
OR
Put the dynomat without removing the plastic sheet?
OR
r33dm0n3y
Feb 18, 2009 04:35 PM
