b16a swap , shift linkage , axles
ok i have a 1990 crx and i am swapping in a b16a. now the problem is the shift linkage i bought from the company who sold me the motor seems to be bout 2-3 inches to long. does anyone know if i should cut and reweld both the shift linkage ad the stabalizer the same amount?? then the axles i ordered from the company dont fit. sp what axles should i go buy from my local shop??? any helpfull advice would be nice.
thanks guys
evan
thanks guys
evan
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trexb16 »</TD></TR><TR><TD CLASS="quote">ok i have a 1990 crx and i am swapping in a b16a. now the problem is the shift linkage i bought from the company who sold me the motor seems to be bout 2-3 inches to long. does anyone know if i should cut and reweld both the shift linkage ad the stabalizer the same amount?? then the axles i ordered from the company dont fit. sp what axles should i go buy from my local shop??? any helpfull advice would be nice.
thanks guys
evan</TD></TR></TABLE>
beautiful Ft. Myers Florida...
90-93 teg axles..
first off, try and bolt in the linkage and see if it actually is too long
if you have hasport mounts, 90-93 linkage cutting off 2 3/8 inch will do the
trick
see if you have the 90-93 linkage first..good luck!
thanks guys
90-93 teg axles..
trick
i have mounted the shift linkage up about 7 times now...i mounted it up in the back and tried to make it work then did the frnt and tried to make it squeeze in. but i will try the 2 3/8 and weld it and see if that fits good..and i thought the axles i got were 90-93 axles...they fit in the hole but wouldnt slide in nice and easy...maybe i just need to buy new ones
crx4ever
Jun 12, 2006 09:45 PM
billyonaire
Oct 3, 2004 05:51 AM
trexb16
Nov 27, 2003 07:54 PM
The AntiRice
Dec 4, 2002 07:19 PM
